0 Replies Latest reply on Sep 14, 2006 4:44 AM by Sir_Lamorack
    UTF-8 doesnt work...
    Sir_Lamorack
      Hi Forum.
      I have some troubles using UTF.
      Environment:
      - Client (developer machine):
      Windows XP SP2 (spanish)
      Dreamwever 8.0.1 (spanish)
      - Test server:
      Windows 2003 Server (English)
      Coldfusion 7.0.1 updated (English)
      This is the way:
      We create a new document in DW, Dynamic->Coldfusion, with HTML4 Transitional DTD, UTF-8 encoding by default, Unicode fonts selected at Edit-Preferences-Fonts.
      We put some text in the body (ññ ?¿ ?¿ áéíóú), saving it as .cfm file in a network share, directly published at http://server/file.cfm
      The encoding doesn´t work!!! we only take a lot of "A^ ?? E^", etc.
      Now: We open the .cfm file with Notepad and save it (selecting UTF-8 in Save As...) without any change as the same file.cfm, try again http://server/file.cfm and it works!!!
      The same file.cfm renamed as file.htm works fine too.
      I´m a little bit desesperated, Maybe DW puts a shadow header in the file? Where can i change that?
      We have Similar troubles with an XML file some days ago, but the resolution was easyest, because that was only 1 file, but we works on several .cfm projects, and that way (open Notepad and save each file) is amazing.
