1 Reply Latest reply on Sep 18, 2006 5:58 AM by hsivaram
    Datagrid CheckBox Update Database
    phillips1021 Level 1
      Anyone know of a good tutorial or other resource for using checkboxes in a datagrid that the user can then click on and then click on a button below the datagrid. The button click will call a function that should update the database for just the rows the user has clicked (ie update the record for that row).
      I've got the checkbox displaying on the datagrid, but I cannot figure out the code for the function to process the rows that the user checked. Is there some way to iterate over the datagrid and determine if the row's check box was selected?
      Bruce
        • 1. Re: Datagrid CheckBox Update Database
          hsivaram
          This is a sample implementation for your question:
          CheckRenderer.mxml (Item Renderer)
          <mx:Canvas xmlns:mx=" http://www.adobe.com/2006/mxml" width="400" height="300">
          <mx:Script>
          <![CDATA[
          public var _sel:Boolean
          public var _ix:Number
          override public function set data(value:Object):void
          _sel=value.data;
          _ix=value.idx
          cx.selected = _sel
          </mx:Script>
          <mx:CheckBox id="cx" click="parentApplication.modifyData(_ix,cx.selected)"/>
          </mx:Canvas>
          Main,mxml
          <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="setData()">
          <mx:Script>
          <![CDATA[
          import mx.collections.ArrayCollection;
          public var arr:ArrayCollection
          public function setData():void
          arr=new ArrayCollection()
          for(var i:int=0;i<17;i++)
          arr.addItem({label:"image"+(i+1),data:false,idx:i})
          dg.dataProvider=arr;
          public function modifyData(ix:Number,sel:Boolean):void
          arr.getItemAt(ix).data=sel
          private function showSel():void
          ta.text=""
          for(var i:int=0;i<dg.dataProvider.length;i++)
          ta.text+="State of record "+i+":" +dg.dataProvider.getItemAt(i).data+"\n";
          </mx:Script>
          <mx:DataGrid x="246" y="133" width="200" height="200" id="dg" rowHeight="25">
          <mx:columns>
          <mx:DataGridColumn headerText="Column 1" dataField="label"/>
          <mx:DataGridColumn headerText="Column 2" dataField="data" itemRenderer="CheckRenderer"/>
          </mx:columns>
          </mx:DataGrid>
          <mx:Button x="583" y="256" label="Track" click="showSel()"/>
          <mx:TextArea x="456" y="133" height="115" width="192" id="ta"/>
          </mx:Application>
          Run main.mxml. after clicking checkboxes, click on the 'Track' button which will display the selection states of each record in the textarea, Hope this helps!
