• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Select Statement Help
Participant ,
Aug 18, 2006 Aug 18, 2006
I havent run this yet as there is still much work to be done. but, this is the beginnings. i am uploading a csv file and selecting data from tables and bulk inserting the rows into a table.
My question is: so far, will this work?? the left join that has to have two matching variables... is that how i would do it?
and am i putting the select in the right place in the cfloop?
thanks for any input on this one.
<cffile action="UPLOAD" filefield="clockfile" destination="#ExpandPath('uploadFolder')#" nameconflict="overwrite" >
<cfset CRLF = Chr(13) & Chr(10)>
<cffile action="READ" file="#ExpandPath('uploadFolder')#/clocktest.csv" variable="csvData">
FILE LAYOUT:
#csvArray[1]#,#csvArray[2]#,#csvArray[3]#,#csvArray[4]#,#csvArray[5]#
Number, export code, regular, overtime, dbl time
empl_code, assign_no, regular, overtime, dbl time
<cfloop index="csvRecord" list="#csvData#" delimiters="#CRLF#">
<cfset csvArray = ArrayNew(1)>
<cfset csvCellCount = 1>
<cfloop index="csvCell" list="#csvRecord#" delimiters=",">
<cfset csvArray[variables.csvCellCount] = csvCell>
<cfset csvCellCount = csvCellCount + 1>
</cfloop>
<cfquery name="rsMatch" datasource="standard">
SELECT a.branch_code, a.bus_segment, a.cust_code, a.cust_dept, a.order_num, a.reference, a.reference2, wk.wc_class, c.wc_state_no,
wr.wc_rate, o.wc_code, a.reg_prate, a.reg_brate, a.ovt_prate, a.ovt_brate, a.dbl_prate, a.dbl_brate, a.bill_to_code, a.owner_num,
a.taker_num, cb.slsp_code, cb.sls_are_code, a.type_service
FROM (((((informix.styasgne a
LEFT JOIN informix.styordre o ON a.order_num = o.order_num)
LEFT JOIN informix.strcustr c ON a.cust_code = c.cust_code)
LEFT JOIN informix.strcbsgr cb ON a.cust_code = cb.cust_code AND (a.bus_segment = cb.bus_segment))
LEFT JOIN informix.stywcskr wk ON o.wc_code = wk.wc_code)
LEFT JOIN informix.stywcrtr wr ON wk.wc_class = wr.wc_class)
WHERE a.assign_no = '#csvArray[2]#'
</cfquery>
<cfquery datasource="standard">
INSERT INTO paywetmp
batch_no, batch_rec, batch_pflag, batch_user_num, batch_date, merge_no, empl_code, week_end, branch_code, bus_segment,
cust_code, cust_dept, order_num, assign_no, reference, reference2, wc_class, wc_state_no, wc_rate, wc_base_amt, wc_amt,
wc_code, reg_phrs, reg_prate, reg_pamt, reg_bhrs, reg_brate, reg_bamt, ovt_phrs, ovt_prate, ovt_pamt, ovt_bhrs, ovt_brate,
ovt_bamt, dbl_phrs, dbl_prate, dbl_pamt, dbl_bhrs, dbl_brate, dbl_bamt, tot_phrs, tot_pamt, tot_bhrs, tot_bamt, tot_mtax_pamt,
tot_mtax_bamt, tot_mded_pamt, tot_mded_bamt, reg_pa, reg_at, ovt_pa, ovt_at, dbl_pa, dbl_at, tsht_type, bill_to_code, owner_num,
taker_num, slsp_code, sls_area_code, type_service, cl_week_end, billed, tot_mntx_pamt, tot_mntx_bamt, pay_type, pay_year,
pay_month, pay_qtr, pay_period, gl_period, gl_year, div_code
VALUES
**blah blah**
</cfquery>
</cfloop>
TOPICS
Advanced techniques
Views
357
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
I took a cursory look. Unless the blah blah blah part includes something from your select query, why bother running it?
Votes
Translate
Translate
Report
Report
Participant ,
yes dan, it is, but that isnt where my problem is, i just shortened the code. is the rest of it ok?
Votes
Translate
Translate
Report
Report
Participant ,
Aug 19, 2006 Aug 19, 2006
The insert will only use the first row from the prior query. If you might have multiple rows you could put a cfloop around the insert but it would be faster to just combine the insert and select queries.
Votes
Translate
Translate
Report
Report
Participant ,
Aug 21, 2006 Aug 21, 2006
LATEST
no, that part works fine. in fact, i have gotten the whole page to act right thnx, here is the whole code if it can help someone else out with it.
cfmx 6.1
informix 7.3.1
bulk loader
csv loader
<cfset CurrentPage=GetFileFromPath(GetTemplatePath())>
<cfif IsDefined("FORM.InsertRecord") AND FORM.InsertRecord EQ "loadreceiver">
FILE LAYOUT:
<cfquery name="rsPeriod" datasource="standard">
SELECT curr_year, curr_month, curr_qtr, curr_period
FROM stycurpd
</cfquery>
<cfset current_batch_number = form.batch_no>
<cfset current_record_number = 0>
<cfset current_record_number = current_record_number + 1>
<cfif current_record_number EQ 100>
<cfset current_batch_number = current_batch_number + 1>
<cfset current_record_number = 1>
</cfif>
</cfloop>
SELECT
a.branch_code, a.bus_segment, a.cust_code, a.assign_dept, a.order_num, a.reference1, a.reference2, wk.wc_class, c.wc_state_no,
wr.wc_calc_rate, o.wc_code, a.reg_prate, a.reg_brate, a.ovt_prate, a.ovt_brate, a.dbl_prate, a.dbl_brate, a.bill_to_code, a.owner_num,
a.taker_num, cb.slsp_code, cb.sls_area_code, a.type_service
FROM standard:informix.styasgne a, standard:informix.styordre o, standard:informix.strcustr c, standard:informix.strcbsgr cb, standard:informix.stywcskr wk, standard:informix.stywcrtr wr
WHERE (a.order_num=o.order_num) AND (a.cust_code=c.cust_code) AND (c.cust_code=cb.cust_code) AND (o.wc_code=wk.wc_code) AND (wk.wc_class=wr.wc_class) AND a.assign_no='#csvArray[2]#'
</cfquery>
VALUES
#current_batch_number#
#current_record_number#
<cfif IsDefined("FORM.batch_pflag") AND #FORM.batch_pflag# NEQ "">
'#FORM.batch_pflag#'
<cfelse>
NULL
</cfif>
<cfif IsDefined("FORM.batch_user_num") AND #FORM.batch_user_num# NEQ "">
'#FORM.batch_user_num#'
<cfelse>
NULL
</cfif>
<cfif IsDefined("FORM.batch_date") AND #FORM.batch_date# NEQ "">
'#FORM.batch_date#'
<cfelse>
NULL
</cfif>
0
#csvArray[1]#
<cfif IsDefined("FORM.week_end") AND #FORM.week_end# NEQ "">
'#FORM.week_end#'
<cfelse>
NULL
</cfif>
'#rsMatch.branch_code#'
'#rsMatch.bus_segment#'
#rsMatch.cust_code#
'#rsMatch.assign_dept#'
#rsMatch.order_num#
#csvArray[2]#
'#rsMatch.reference1#'
'#rsMatch.reference2#'
'#rsMatch.wc_class#'
'#rsMatch.wc_state_no#'
#rsMatch.wc_calc_rate#
#ABS(ABS(csvArray[3] + csvArray[4] + csvArray[5]) * rsMatch.reg_prate)#
#ABS(ABS(ABS(csvArray[3] + csvArray[4] + csvArray[5]) * rsMatch.reg_prate) * rsMatch.wc_calc_rate)#
'#rsMatch.wc_code#'
#csvArray[3]#
#rsMatch.reg_prate#
#ABS(csvArray[3] * rsMatch.reg_prate)#
#csvArray[3]#
#rsMatch.reg_brate#
#ABS(csvArray[3] * rsMatch.reg_brate)#
#csvArray[4]#
#rsMatch.ovt_prate#
#ABS(csvArray[4] * rsMatch.ovt_prate)#
#csvArray[4]#
#rsMatch.ovt_brate#
#ABS(csvArray[4] * rsMatch.ovt_brate)#
#csvArray[5]#
#rsMatch.dbl_prate#
#ABS(csvArray[5] * rsMatch.dbl_brate)#
#csvArray[5]#
#rsMatch.dbl_brate#
#ABS(csvArray[3] + csvArray[4] + csvArray[5])#
#ABS(ABS(csvArray[3] * rsMatch.reg_prate))+ (ABS(csvArray[4] * rsMatch.ovt_prate)) + (ABS(csvArray[5] * rsMatch.dbl_prate))#
#ABS(ABS(csvArray[3] * rsMatch.reg_brate))+ (ABS(csvArray[4] * rsMatch.ovt_brate)) + (ABS(csvArray[5] * rsMatch.dbl_brate))#
0
0
0
0
0
0
0
0
0
0
'R'
'#rsMatch.bill_to_code#'
#rsMatch.owner_num#
#rsMatch.taker_num#
'#rsMatch.slsp_code#'
'#rsMatch.sls_area_code#'
'#rsMatch.type_service#'
'#FORM.week_end#'
<cfelse>
NULL
</cfif>
'N'
0
0
'W'
#rsPeriod.curr_year#
#rsPeriod.curr_month#
#rsPeriod.curr_qtr#
#rsPeriod.curr_period#
'MZZ'
</cfquery>
</cfloop>
<cflocation url="index.cfm">
</cfif>
<html>
<head>
<title>Load Clock File</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
</head>
<body>
<form name="loadreceiver" action="<cfoutput>#CurrentPage#</cfoutput>" method="post" enctype="multipart/form-data">
<div align="center">
<input type="file" name="clockfile">
<br />
</div>
<table width="80%" border="1" align="center" cellpadding="3" cellspacing="1">
<tr valign="baseline">
<td nowrap align="right">Batch Begin:</td>
<td><input type="text" name="batch_no" value="" size="32"></td>
</tr>
<td nowrap align="right">User Number:</td>
<td><input type="text" name="batch_user_num" value="<cfoutput>#cgi.AUTH_TYPE#</cfoutput>" size="32"></td>
</tr>
<td nowrap align="right">Client End Date:</td>
<td><input type="text" name="week_end" value="<cfoutput>#today#</cfoutput>" size="32"></td>
</tr>
<td nowrap align="right">Pull Flags: </td>
<td><input name="batch_pflag" type="text" id="batch_pflag" size="3"></td>
</tr>
<td colspan="2" align="right" nowrap><div align="center">
<input type="submit" value="Load Clock File">
</div></td>
</tr>
</table>
<input type="hidden" name="InsertRecord" value="loadreceiver">
<input type="hidden" name="batch_date" value="<cfoutput>#dateformat(NOW(), 'yyyy-m-d')#</cfoutput>">
</form>
</body>
</html>
Votes
Translate
Translate
Report
Report
Resources
Documentation
