0 Replies Latest reply on Aug 18, 2006 4:06 PM by jd-lingwai
    Check box
    jd-lingwai
      here's the seniero:
      I made a datagrid from a dataprovider(first column is a checkbox, second column is the name). I then have another datagird which includes the name from the first datagrid and more data. The problem comes when I click on the check box. I'm unable to update the second grid data to remove/add the data. here is the code for the click on the check box. If you can see what I'm doing wrong please inform me. I can't get the InGraph to change from true to false
      thanks
      private function StateClick():void
      var y:int;
      var Selected:Array;
      Selected = new Array();
      Selected = dgStates.selectedItems;
      SelectedState = new Array();
      if(dgStates.selectedItems.selected == true ){
      Selected.InGraph = false;
      } else {
      Selected.InGraph = true ;
      SelectedState = Selected;
