2 Replies Latest reply: Sep 22, 2006 3:02 AM by BKBK RSS
    Possible corrections for the JMS Gateway code?
    BKBK Community Member
      The JMS specifications require the JMS Provider to set the client ID by default, not the client to set his own ID. Coldfusion's code will therefore generate an Exception with most JMS servers.
      To correct the problem, comment out the following lines of code
      JMSConsumer.java
      this.connection.setClientID(this.configuration.getSubscriberName());
      JMSPublishConnection.java
      this.connection.setClientID(this.configuration.getPublisherName(this.topicName));
      The following code snippet from JMSGateway.java looks very much like an error
      if (sendMessage(cfMsg))
      log.info("Added message '" + msgID + "' to queue.");
      I think it should be something like
      boolean messageSent = gatewayService.addEvent(cfMsg);
      if (messageSent)
        • 1. Possible corrections for the JMS Gateway code?
          My suggested correction for the JMSGateway.java code assumes that the variable gatewayService has already been defined. However, the current code doesn't define it.
          Here follows a suggestion that doesn't assume that gatewayService is defined beforehand.
          1) Add the following line to the JMSGateway.java code:
          import coldfusion.eventgateway.GatewayServices;
          2) Modify the code snippet in my original post to
          boolean messageSent = (boolean) GatewayServices.getGatewayServices().addEvent(cfMsg);
          if (messageSent)
          3) Added edit:
          (a) You may have to add the following lines at the appropriate places:
          private String gatewayID; (add it where the other private variables are declared)
          this.gatewayID = gatewayID; (add it just under the line super(gatewayID);)
          (b) Replace the line CFEvent cfMsg = new CFEvent(getGatewayID()); with
          CFEvent cfMsg = new CFEvent(gatewayID);
          • 2. Re: Possible corrections for the JMS Gateway code?
            To correct the problem, comment out the following lines of code...
            Perhaps too drastic. It would be more graceful to use try/catch instead, especially as a durable subscriber may have occasion to call setClientID(). Thus, for example, in JMSConsumer.java, do
            try {
            }catch (IllegalStateException e) {System.out.println(e);}
            Thanks to Sean Corfield for the remark
