6 Replies Latest reply on Aug 20, 2006 11:03 AM by Newsgroup_User
    Unwanted lines and a disappearing act
    itsreallyme
      I'm finding that, when allowed to sit for a little over a minute, black vertical lines appear to left and right of certain movie clips. After another 30 seconds or so, the movie clips disappear altogether. Here's a link to the site:
      problem site
      Simply navigate to one of the sections ("LOGOS," "ADVERTISING," or "PACKAGING") and select one of the portfolio pieces from the short stack of circles in the lower-left corner. Let it sit for about a minute. The lines should appear on the left and on the right. Let it sit a little longer and the portfolio piece should just plain disappear.
      Any ideas why this is happening?
      --bwaldo
        • 1. Re: Unwanted lines and a disappearing act
          Level 7
          "itsreallyme" <webforumsuser@macromedia.com> wrote in message news:ec6li2$qv5$1@forums.macromedia.com...
          > site:
          > http://www.annsmalley.com/annsmalley.htm
          I didn't see the lines and nothing disappeared. I tried several of them for a couple of minutes.
          Maybe it's something wrong with your PC. (after 1 minute of inactivity, something else starts running)
          tralfaz
          • 2. Re: Unwanted lines and a disappearing act
            itsreallyme Level 1
            Hmm. Well, I guess that's good news, then. I'll do a little more investigatin' at my end. Bizarre....
            It's unlikely, too, that anyone's going to park on one of those screens for anywhere NEAR that long, but I just found it annoying and was curious about what could be causing it.
            Thanks for taking a look, Tralfaz!
            • 3. Re: Unwanted lines and a disappearing act
              itsreallyme Level 1
              Okay. I've tested this on different machines and different browsers. I get the same result--the result I reported initially. Wait long enough, and the vertical lines on either side of the image appear. Wait a little longer and the image disappears. The key is to wait long enough. But it will happen.
              • 4. Re: Unwanted lines and a disappearing act
                Level 7
                "itsreallyme" <webforumsuser@macromedia.com> wrote in message news:ec86dc$hra$1@forums.macromedia.com...
                The onEnterFrame for the fadeIn function is not being ended correctly because 'this' is not pointed to the correct object. The
                onEnterFrames calling the fadeIn function are 3 different ones and the called function doesn't have a pointer to know which
                onEnterFrame called it. I wouldn't use onEnterFrames for what you are doing anyway. Here is a suggested replacement for your
                fadeIn function:
                function portPieceFadeIn(instanceName)
                var mc = _root.portfolio_mc.portPieceContainer_mc[instanceName];
                mc._alpha += 5;
                if (mc._alpha > 95)
                mc._alpha = 100;
                clearInterval(id1); // end the setInterval timer
                // And the 3 places that call that function
                // (looks like this one)
                _root.portfolio_mc.portPieceContainer_mc.BBVDPosterBack_mc.onEnterFrame = function ()
                portPieceFadeIn("BBVDPosterBack_mc");
                Change those 3 to these 2 lines:
                clearInterval(id1); // avoid multiple copies of the timer
                id1 = setInterval(portPieceFadeIn, 50, "BBVDPosterBack_mc"); // 50ms = 20fps
                // and this..
                id1 = setInterval(portPieceFadeIn, 50, "bbvdLogo_mc"); // 50ms = 20fps
                // and this...
                id1 = setInterval(portPieceFadeIn, 50, "bbvdSleeveFront_mc"); // 50ms = 20fps
                I tested it with this code and it got rid of the problem of the images disappearing. I never did see the lines you mentioned
                though.
                tralfaz
                • 5. Re: Unwanted lines and a disappearing act
                  itsreallyme Level 1
                  Wow! That worked perfectly! Tralfaz--thank you for taking so much time to figure out what was wrong, and then write & test a solution to it. I never would've figured that out myself.
                  Take care....
                  • 6. Re: Unwanted lines and a disappearing act
                    Level 7
                    "itsreallyme" <webforumsuser@macromedia.com> wrote in message news:ec9br4$pk9$1@forums.macromedia.com...
                    > Take care....
                    Great. Glad to help out.
                    tralfaz
