2 Replies Latest reply on Sep 15, 2006 5:38 AM by ljonny18
    comboBox + get value
    ljonny18 Level 1
      Hi all,
      I am using a comboBox and calling an mx:Script function using the "Change" property within the comboBox......
      if I populate the comboBox manually, e.g:
      <mx:ComboBox id="test_cb" change="getCbVal()">
      <mx:dataProvider>
      <mx:Array>
      <mx:String>a</mx:String>
      <mx:String>b</mx:String>
      <mx:String>c</mx:String>
      </mx:Array>
      </mx:dataProvider>
      </mx:ComboBox>
      I can get the value of the comboBox and thus perform some sort of action within the ms:Script function, e.g:
      if(test_cb.value == "b")
      test_cb.enabled=false
      etc..........................
      but when I try to populate the comboBox using another (dynamic) method such as a web-service - the function is called but the values of the comboBox cannot be recognised.......
      is there another method of doing this using a web-service population (replacement of .value????)
      any suggestions?
      Jon.
