1 Reply Latest reply on Jun 29, 2006 10:47 PM by ensamblador
    at my wits end
      I have been trying to do what I thought would be a very simple project. I created a 3d environment with simple objects I would like the user to be able to re-arrange in that environment. I would like the user to be able to rotate around the model so they can see it from the front, top, back and bottom.
      Using the built in 3d behaviors I assign command to move an object on each axis separately, and to rotate on the x axis. This all works fine until I rotate the camera to a new position. Once the camera moves, the x,y and z axis of the objects seem to follow the camera, so now a vertical or front to back move is no longer on the correct plane.
      I thought it might be the program I created the model it, but it acts the same if I use Maya, Studio Max or Shape shifter.
      Any idea what I am doing wrong and how I can fix it?
      Michael
        • 1. Re: at my wits end
          ensamblador Level 1
          I think that the axis of the model don't follow the camera, that is the reason of your problem.
          Use the following sintax for rotating the models:
          member(whichCastmember).node(whichNode).rotate(position, axis, angle {, relativeTo})
          position=position of the model
          axis= vector indicating the axis of rotation, use a camera axis (x,y or z)
          angle= the angle
          relativeTo=#self
          With this, the model will always rotate in the same way, no matter the camera transform.
          Luck.
