2 Replies Latest reply on Jun 30, 2006 8:55 AM by jrief
    Problem accessing results from DataService fill method
    jrief
      I've set up an application that gets data from a data service
      configured with a java-dao adapter. If I define a DataGrid with the
      array populated by the fill method I see the data in the grid. Cool.
      So I know I've configured and coded everything correctly.
      However, if I try to access the data with the following code, it
      appears my array is empty!
      ray = new ArrayCollection();
      ds = new DataService("assets");
      ds.fill(ray);
      var asset:Asset = ray[0];
      This gives me an index '0' out of bounds error. I've also tried
      ray.getItemAt(0) with the same results.
      How do I access and manipulate the results of a fill method via
      ActionScript? I'm currently using Beta3.
