2 Replies Latest reply on Jul 3, 2006 4:15 PM by NewMediaRoc
    dynamic playback for .FLVs
    NewMediaRoc Level 1
      I had read in another form that changing the speed at which an FLV plays is not possible unless you create keyframes every frame in the FLV. I hope this is not the case. I'm wondering if anyone else has found a solution to this problem. Possibly by changing the FPS? or creating some way of using cue points to play back at different speeds? Let me know, thanks.
        • 1. Re: dynamic playback for .FLVs
          derobinson
          You can't change the FPS of an FLV dynamically. What I've done to fake it..and gotten decent results...is put the FLV in a movieclip on the stage and stop that movie clip. Then I use setInterval with a dynamic interval to call a function which tells the MC to go to the next frame. When you want to change the apparent framerate of the FLV, you clear the interval and reset it with a new interval variable. Here's the setInterval call:
          fpsSet = setInterval(playNextFrame,1000/myFPS,myVid);
          Hope that helps!
          • 2. Re: dynamic playback for .FLVs
            NewMediaRoc Level 1
            Sounds like an interesting solution! I will have to try playing with that soon! Thanks for the idea! I'll let you know how it turns out
