1 Reply Latest reply on Jul 28, 2006 7:52 PM by Newsgroup_User
    aval help needed!
    Spot3313
      Hey,
      Im trying to create a login system using XML - i found a flash movie that explains it, however it was created in Flash 5. Could anyone help me out and possibly provide a soultion!
      If needed I can send the file! Thank you to everyon that may be able to help!
      Here is part of the code
      function load_usrXML(success) {
      if (success) {
      var staff = usrXML.firstChild.firstChild;
      i=1;
      while (staff != null) {
      eval (staff.attributes.TITLE) = staff.attributes.NAME;
      eval (staff.attributes.PASSTITLE) = staff.attributes.CODE;
      if (staff.attributes.NUM eq "accountnum") {
      eval(staff.attributes.NUM) = staff.attributes.VALUE;
      staff = staff.nextSibling;
      } else {
      trace("error Loading XML File");
      setObj();
        • 1. Re: aval help needed!
          Level 7
          In Flash 5 or later, you cannot use eval() to dynamically set and retrieve
          the value of a variable or instance name, because you cannot useeval() on
          the left side of an equation. For example, replace the code
          eval ("var" + i) = "first";
          with this:
          this["var"+i] = "first"
          or this:
          set ("var" + i, "first");
          http://livedocs.macromedia.com/flash/8/main/00001726.html
          Lon Hosford
          www.lonhosford.com
          Flash, Actionscript and Flash Media Server examples:
          http://flashexamples.hosfordusa.com
          May many happy bits flow your way!
          "Spot3313" <webforumsuser@macromedia.com> wrote in message
          news:eadlc6$mpl$1@forums.macromedia.com...
          > Hey,
          > and
          > help!
          > if (success) {
          > i=1;
          > } else {
          > setObj();
