3 Replies Latest reply on Jun 29, 2006 5:40 AM by Newsgroup_User
    MovieClip resizeing
    Tolk
      I have a movieClip attached to an external class file, the class file takes data and uses it to draw an bar chart ino the movieClip.
      If you re-size the movieClip and then compile everything displays correctly but obviously all elements in the movieClip are enlarged/shrunk depending on how you re-sized.
      I want to make my movieClip so that when it is resized certain elements stay their original size (text size, line thickness) and others are enlarged/shrunk to match the movieClip size (fill areas).
      How would i go about doing this, can it be done.
      The same as how when you re-size a component the text etc. stays the same size (and the position updates) but fill areas are enlarged/shrunk.
