3 Replies Latest reply on Jul 30, 2006 9:47 AM by Newsgroup_User
    GIF and loadMovie()
    BernardoLira
      Hi all.
      I'm a rookie using Flash, and I need to loadMovie a GIF file.
      When using loadMovie() with JPG file it works fine, but when file is GIF it doesn't load. I cannot change the file format but need to dynamically load those files.
      Any hints will be very appreciated.
      Thanks in advance
      Bernardo
        • 1. Re: GIF and loadMovie()
          simple, you cannot load GIF in any version of flash except Flash 8. Flash 8 support also png file and progresive JPG.
          So you only have 2 choices:
          1- using jpg image format
          2- switch to Flash 8
          I know its weird that earlier version of Flash does not support GIF and PNG loading but at least now Flash 8 do.
          • 2. Re: GIF and loadMovie()
            BernardoLira Level 1
            Thanks, butcho.
            Upgrading to 8 seems to be the way. BTW, I don't suppose there is a patch to solve this "omission".
            Bernardo
            • 3. Re: GIF and loadMovie()
              Level 7
              > progresive JPG.
              Please note, this should read Flash 8 *or higher*. The current version
              of the Flash Player is 9, and it supports all of 8's features, pluse more.
              There is no patch. Flash Players 7 and below are what they are, and the
              Flash MX 2004 (aka 7) IDE is what it is. There are a number of open source,
              free alternative to the Adobe Flash IDE (see http://osflash.org), so that
              may help you out.
              David
              stiller (at) quip (dot) net
              Dev essays: http://www.quip.net/blog/
              "Luck is the residue of good design."
