2 Replies Latest reply on Jun 29, 2006 11:47 AM by MergeThis
    Linking within the Glossary?
    Avon_01 Level 1
      From the Definition area of the glossary: is it possible to create a link for the user to go to a topic? For example. IRS Codes: The IRS uses several codes to ......, click on this link to access a table of codes.
        • 1. Re: Linking within the Glossary?
          RoboColum(n) Level 5
          I'm afraid there is no way to create links from the glossary definition.
          • 2. Re: Linking within the Glossary?
            MergeThis Level 4
            If you create a Glossary topic (instead of the RH default, that is), you could create all the links you want. For accessing this topic file, you can add an icon/label in the toolbar of your skin, or you can add a Glossary link in every topic.
            Conversion shouldn't be too bad: the info in the .GLO file (sample below) can be easily converted. Create a style for the term and description paragraphs, assign them to the info, then strip all of the "NAME=" identifiers.
            NAME=Glossary
            Description
            NAME=Test
            Definition 2
            Leon
