2 Replies Latest reply on Jul 28, 2006 10:00 PM by WebXperience
    dynamically creating objects
    Level 7
      Does anyone know if you can dynamically create an object from the string
      name of the class?
      For example, if you have a class TestObj
      Instead of hard coding it like this:
      obj = new testObj();
      Could you do something like this:
      className = "TestObj";
      obj = new [className ]();
      or some such construct that would allow you to instaniate an a class on the
        • 1. Re: dynamically creating objects
          injpix Level 3
          That seems awkward to code like that. I suppose you can create a symbol in the library and have it access ‘TestObj’ then call it out onto the stage using attachMovie(). But it would seem that using a switch statement would even be more practicable for your request.
          • 2. Re: dynamically creating objects
            WebXperience Level 1
            The code for defining an ActionScript class exists in its own .as file.
            class Cube (
            var length:Number;
            var height:Number;
            var width:Number;
            functionCube(tempLength:Number, temHeight:Number, tempWidth:Number) {
            length = tempLength;
            height =tempheight;
            width = tempWidth;
            function getVolume():Number {
            return length * height * width;
            After creating the class and saving it as an .as file in the same directory as your Flash authoring fie. You would create a new instance of the class in the following way:
            var myCube:Cube = new Cube(3, 2, 7);
