Welcome to the forum.
I suspect this will be one of several things.
1] You have not installed the patch for Word 2003. Under
Help, select Check for Updates.
2] Your normal template is not on your hard disk.
3] RH was not installed using your login. I suspect though
you would have other problems.
4] Your project is not on your hard disk.
5] You are trying to generate to the network.
Give me some more information about those areas.
