2 Replies Latest reply on Jun 28, 2006 12:17 PM by Newsgroup_User
    How to declare a new Data Type?
    ihtus
      I have a new Data type ( fxn ) declared in delphi, and i would like to convert the code to actionscript
      quote:
      type fxn=procedure(t:extended;x:array of extended;var f:array of extended);
      procedure fp(t:extended;x:array of extended;var f:array of extended);
      begin
      f[0]:=x[1];
      f[1]:=-sin(x[0])*(g/ll);
      end;
      procedure r_kutta6(eps,t0:extended;x0:array of extended;fnx:fxn;
      var t:extended;var x:array of extended);
      begin
      fnx(t0,x0,f); //means fp(t0,x0,f); - when applying the procedure.
      end;
      r_kutta6(0.0001,t0,xx0,fp,t,xx);
      how can i declare in actionscript such a new data type, and after - to use as i do in delphi
      thanks!
        • 1. Re: How to declare a new Data Type?
          Level 7
          ihtus,
          It goes without saying that any new datatype in ActionScript can only do
          what ActionScript is inherently capable of doing. Your sample code looks
          fine, in that regard. To declare a datatype in ActionScript 2.0, you'll
          have to write your own class.
          Check out Joey Lott's three-part ActionScript 2.0 Primer for details.
          http://www.person13.com/articles/
          David
          stiller (at) quip (dot) net
          Dev essays: http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: How to declare a new Data Type?
            Level 7
            If you want to pass a function (pointer) as an argument, you can just do so.
            function fp(t,x,f)
            f[0]=x[1];
            f[1]= -Math.sin(x[0])*(g/ll);
            function r_kutta6(eps,x0,fnx,t,x)
            "ihtus" <webforumsuser@macromedia.com> wrote in message
            news:e7uhlp$qig$1@forums.macromedia.com...
            convert
            extended);
            > begin
            > f[0]:=x[1];
            > end;
            > begin
            > end;
            use as
            > i do in delphi
            > thanks!
