6 Replies Latest reply on Jul 3, 2006 1:11 PM by targetplanet
    Error Using ColdFusion/Flex Application Wizard
      I am eager to use the CRUD capabilities of the CF/Flex App wizard. After 4 hours of trying to find the problem, though, perhaps someone else can help. The wizard is able to locate and work with a SQL Server 2005 datasource and create the application. When i run it however, i receive the following error:
      (mx.rpc::Fault)#0
      errorID = 0
      faultCode = "Client.Error.MessageSend"
      faultDetail = "Channel.Connect.Failed error NetConnection.Call.Failed: HTTP: Status 405"
      faultString = "Send Failed"
      message = "faultCode: Client.Error.MessageSend
      faultString = 'Send failed'
      name="Error"
      rootCause = (Object) #1
      code = "NetConnection.Call.Failed"
      description = "HTTP: Status 405"
      details = " http://localhost/flex2gateway"
      level = "error"
      1. Flex Integration is enabled on my 7.0.2 server
      2. This looks like a mapping issue
      Someone help, please?
      Christian Briggs
