1 2 Previous Next 67 Replies Latest reply on Oct 1, 2006 3:06 PM by kglad
    Movieclip button
    angelina28 Level 1
      Hi! I have a movieclip button and this is my code:
      b1.onRelease = function() {
      _root.b1.gotoAndStop(6);
      b1.onRollOver = function() {
      _root.b1.gotoAndPlay(2);
      b1.onRollOut = function() {
      _root.b1.gotoAndPlay(7);
      b1 is the name of my movieclip button. When the user clicks the button, I want to stop the button at frame 6. This works fine if I take out the onRollOut function. But I need to somehow keep the OnRollOut, but I don't know how to keep it from interfering with the onRelease function.
      Thanks in advance for any help or suggestions.
        • 1. Re: Movieclip button
          Level 7
          angelina28,
          Okay ...
          Ah. Right off the bat, you may want to use the global "this" property,
          which refers to whatever object or timeline it's in.
          this.gotoAndStop(6);
          Less typing, and also less prone to errors, depending on how long the
          path reference is to the object (here, a movie clip) in question.
          > onRollOut function.
          That makes sense, right? After the use clicks and releases, the user is
          very likely to move the mouse away from the button. The onRollOut event is
          the last one to get triggered.
          > onRelease function.
          Because you're using a movie clip to do this, you have all the features
          that a movie clip provides, including the fact that you can add a script
          layer inside the clip. It's good as a best practice to keep most of your
          code in the main timeline, but I personally think it's fine, here and there,
          to put the occasional stop() or gotoAndStop(), etc. inside movie clip
          timelines. Maybe in frame 8 of b1, you could put gotoAndStop(6). Thus,
          when someone rolls out, the clip will go to frame 7, do its thing, continue
          to frame 8, then stop at frame 6.
          David Stiller
          Adobe Community Expert
          Dev blog, http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: Movieclip button
            TimSymons Level 1
            Are you trying to simulate a toggling effect? Something like a checkbox that has a checked state and an unchecked state?
            If so, that you can do something like this:
            var isToggled:Boolean = false;
            isToggled = true;
            if (isToggled) {
            _root.b1.gotoAndPlay(6);
            } else {
            Tim
            • 3. Re: Movieclip button
              Level 7
              angelina28,
              Okay ...
              > onRollOut function.
              > onRelease function.
              David Stiller
              • 4. Re: Movieclip button
                Level 7
                angelina28,
                Okay ...
                > onRollOut function.
                > onRelease function.
                David Stiller
                • 5. Re: Movieclip button
                  Level 7
                  angelina28,
                  Okay ...
                  > onRollOut function.
                  > onRelease function.
                  David Stiller
                  • 6. Re: Movieclip button
                    Level 7
                    angelina28,
                    Okay ...
                    > onRollOut function.
                    > onRelease function.
                    David Stiller
                    • 7. Re: Movieclip button
                      Level 7
                      angelina28,
                      Okay ...
                      > onRollOut function.
                      > onRelease function.
                      David Stiller
                      • 8. Re: Movieclip button
                        Level 7
                        angelina28,
                        Okay ...
                        > onRollOut function.
                        > onRelease function.
                        David Stiller
                        • 9. Re: Movieclip button
                          Level 7
                          angelina28,
                          Okay ...
                          > onRollOut function.
                          > onRelease function.
                          David Stiller
                          • 10. Re: Movieclip button
                            Level 7
                            angelina28,
                            Okay ...
                            > onRollOut function.
                            > onRelease function.
                            David Stiller
                            • 11. Re: Movieclip button
                              Level 7
                              angelina28,
                              Okay ...
                              > onRollOut function.
                              > onRelease function.
                              David Stiller
                              • 12. Re: Movieclip button
                                Level 7
                                angelina28,
                                Okay ...
                                > onRollOut function.
                                > onRelease function.
                                David Stiller
                                • 13. Re: Movieclip button
                                  Level 7
                                  angelina28,
                                  Okay ...
                                  > onRollOut function.
                                  > onRelease function.
                                  David Stiller
                                  • 14. Re: Movieclip button
                                    Level 7
                                    angelina28,
                                    Okay ...
                                    > onRollOut function.
                                    > onRelease function.
                                    David Stiller
                                    • 15. Re: Movieclip button
                                      Level 7
                                      angelina28,
                                      Okay ...
                                      > onRollOut function.
                                      > onRelease function.
                                      David Stiller
                                      • 16. Re: Movieclip button
                                        Level 7
                                        angelina28,
                                        Okay ...
                                        > onRollOut function.
                                        > onRelease function.
                                        David Stiller
                                        • 17. Re: Movieclip button
                                          Level 7
                                          angelina28,
                                          Okay ...
                                          > onRollOut function.
                                          > onRelease function.
                                          David Stiller
                                          • 18. Re: Movieclip button
                                            Level 7
                                            angelina28,
                                            Okay ...
                                            > onRollOut function.
                                            > onRelease function.
                                            David Stiller
                                            • 19. Re: Movieclip button
                                              Level 7
                                              angelina28,
                                              Okay ...
                                              > onRollOut function.
                                              > onRelease function.
                                              David Stiller
                                              • 20. Re: Movieclip button
                                                Level 7
                                                angelina28,
                                                Okay ...
                                                > onRollOut function.
                                                > onRelease function.
                                                David Stiller
                                                • 21. Re: Movieclip button
                                                  Level 7
                                                  angelina28,
                                                  Okay ...
                                                  > onRollOut function.
                                                  > onRelease function.
                                                  David Stiller
                                                  • 22. Re: Movieclip button
                                                    Level 7
                                                    angelina28,
                                                    Okay ...
                                                    > onRollOut function.
                                                    > onRelease function.
                                                    David Stiller
                                                    • 23. Re: Movieclip button
                                                      Level 7
                                                      angelina28,
                                                      Okay ...
                                                      > onRollOut function.
                                                      > onRelease function.
                                                      David Stiller
                                                      • 24. Re: Movieclip button
                                                        Level 7
                                                        angelina28,
                                                        Okay ...
                                                        > onRollOut function.
                                                        > onRelease function.
                                                        David Stiller
                                                        • 25. Re: Movieclip button
                                                          lol, dave. that's a bit on the extreme side.
                                                          • 26. Re: Movieclip button
                                                            Level 7
                                                            angelina28,
                                                            Okay ...
                                                            > onRollOut function.
                                                            > onRelease function.
                                                            David Stiller
                                                            • 27. Re: Movieclip button
                                                              Level 7
                                                              angelina28,
                                                              Okay ...
                                                              > onRollOut function.
                                                              > onRelease function.
                                                              David Stiller
                                                              • 28. Re: Movieclip button
        Level 7
        angelina28,
        Okay ...
        > onRollOut function.
        > onRelease function.
        David Stiller
        • 29. Re: Movieclip button
        Level 7
        angelina28,
        Okay ...
        > onRollOut function.
        > onRelease function.
        David Stiller
        • 30. Re: Movieclip button
        Level 7
        angelina28,
        Okay ...
        > onRollOut function.
        > onRelease function.
        David Stiller
        • 31. Re: Movieclip button
        Level 7
        angelina28,
        Okay ...
        > onRollOut function.
        > onRelease function.
        David Stiller
        • 32. Re: Movieclip button
        Level 7
        angelina28,
        Okay ...
        > onRollOut function.
        > onRelease function.
        David Stiller
        • 33. Re: Movieclip button
        Level 7
        angelina28,
        Okay ...
        > onRollOut function.
        > onRelease function.
        David Stiller
        • 34. Re: Movieclip button
        Level 7
        kglad,
        lol ... maybe. ;) Tim probably nailed it closer to what the OP
        intended. I'm having a hard time picturing the actual intent.
        David Stiller
        • 35. Re: Movieclip button
        Level 7
        angelina28,
        Okay ...
        > onRollOut function.
        > onRelease function.
        David Stiller
        • 36. Re: Movieclip button
        Level 7
        kglad,
        David Stiller
        • 37. Re: Movieclip button
        Level 7
        angelina28,
        Okay ...
        > onRollOut function.
        > onRelease function.
        David Stiller
        • 38. Re: Movieclip button
        Level 7
        kglad,
        David Stiller
        • 39. Re: Movieclip button
        Level 7
        angelina28,
        Okay ...
        > onRollOut function.
        > onRelease function.
        David Stiller
        1 2 Previous Next
