2 Replies Latest reply on Jan 13, 2009 12:38 PM by amit yunger
    Close Swf  Window
    amit yunger
      I'm trying to create a button that closes an swf file. I've checked many tutorials, but none of them solve this problem.
      I could use fscommand, but I understand it only works for an EXE file, and that creates a lot of security problems...
      All the getURL java stuff doesn’t work, either.
      How can I simply close a window of an swf file??
      [I don't want to use an HTML file because of the browser's panels that will "push" down the window]
      Thank you for your assistance,
        • 1. Re: Close Swf  Window
          robdillon Most Valuable Participant
          How are you planning on showing this file? In the Flash player? If that's the case, then no, there is no way to close a window in the Flash player from within the Flash movie itself.
          If you want to use a browser, you can create a chromeless window with your Flash movie as the content. From there you can close that window, because it will have been opened using Javascript.
          • 2. Re: Close Swf  Window
            amit yunger Level 1
            I have a problem using the browser. I made a courseware that should be displayed all over the screen. The browser's panels push the courseware downward.
            Is there any way of opening the browser without its panels?
