6 Replies Latest reply on Jun 28, 2006 7:13 AM by Newsgroup_User
    Formatting Decimals
    ndisdabest
      I've built a simple Batting Average calculator, but I would like to format the final decimal value so that it doesn't hava a leading zero and only has 3 digits after the decimal point. How do you format decimal values?
      Here's my current code:
        • 1. Re: Formatting Decimals
          Level 7
          Hi!
          Try to change to:
          avg = Math.round(hits/ab*1000)/1000;
          /Jensen/
          "ndisdabest" <webforumsuser@macromedia.com> wrote in message
          news:e7tube$177$1@forums.macromedia.com...
          > the
          > stop();
          > var avg:Number = 0;
          > var hits:Number = 0;
          > var ab:Number = 0;
          > button.onPress = function() {
          > button.gotoAndPlay(2);
          > hits = Number (hitsText.text);
          > ab = Number (abText.text);
          > avg = Number (hits/ab);
          > avgText.text = avg;
          • 2. Formatting Decimals
            ndisdabest Level 1
            That works pretty well... now is there any way to drop the zero before the decimal point?
            I know in ASP you could use the Right function and do something like Right(avgText,4), but I don't know if that functionality exists in ActionScript...
            • 3. Re: Formatting Decimals
              danieldear
              u can also use Math.floor(avg) after calculating avg or
              avg = Math.floor(hits/ab)
              • 4. Re: Formatting Decimals
                Level 7
                Ah, ok ... thought you meant "extra" zeros after decimal ... was a bit
                unsure about that, my fault.
                Well, you can't reformat a _number_ to be displayed that way, so you would
                be forced to turn it into a string.
                I don't know if you ever get any number larger or equal to 1, but that would
                be something you'd need to test first, so
                maybe change code to something like:
                if (avg >= 1) {
                avgText.text = avg;
                } else {
                var s = avg.toString();
                avgText.text = s.substr(1,s.length-1);
                this would give an output like for example
                1.324
                .532
                .076
                If you don't have numbers larger than 1 and you only want to display the
                decimals, so that the example above would be
                532
                76
                then you could just do:
                /Jensen/
                news:e7tv3n$29q$1@forums.macromedia.com...
                > the decimal point?
                • 5. Re: Formatting Decimals
                  ndisdabest Level 1
                  That does it, thanks!
                  • 6. Re: Formatting Decimals
                    Level 7
                    Nah, that won't work as you have it there. Math.floor will remove all
                    numbers after the decimal, and in the example given leave you with 0.
                    Remove '_spamkiller_' to mail
