3 Replies Latest reply on Jan 27, 2009 11:54 AM by Myonlycrummynick
    Inserting object data into a datagrid
    Myonlycrummynick
      Hi guys.
      I'm building a flex application getting data from at webservice. The result from the webservice looks like the coded pasted in at the buttom.
      An array of person-objects each with a single info-object inside it. All is good for the firstname and lastname part, i can use the following code - where event.result is the response from my webservice:
      var arrResult:ArrayCollection = new ArrayCollection();
      arrResult.source = event.result.toArray();
      dg1.dataProvider = arrResult;
      firstnameField.dataField = "Firstname";
      lastnameField.dataField = "Lastname";
      But what if i want to insert the phonenumber into the 3rd column called phoneField? I'd like to use:
      phoneField.dataField = "Info.Phone"; // Not working...
      but that doesn't work, i guess it's because flex does not know whether there is one or 10 info-objects inside each person-object.
      So how do i do it?
      I see i can use Person(arrResult.getItemAt(0)).Info.Phone to extract the value for a specific person-object (here the first in the result, but how do i fill in all of the for each person in the grid?
      Thanks in advance.
      /Nibby
        • 1. Re: Inserting object data into a datagrid
          Level 7
          "Myonlycrummynick" <webforumsuser@macromedia.com> wrote in message
          news:gli9f9$apq$1@forums.macromedia.com...
          > Hi guys.
          > result
          > is
          > where
          Try labelFunction instead.
          HTH;
          Amy
          • 2. Inserting object data into a datagrid
            ntsiii Level 3
            As Amy says, labelFunction is the way to go.
            "labelField: can only take a string, which is the name of a first level property of the item. Usually an object property, or an xml attribute or an xml child node text value.
            It can *not* take an expression, like Info.Phone.
            • 3. Re: Inserting object data into a datagrid
              Myonlycrummynick Level 1
              Sorry for the late answer, you are both right on.
              For the record - i used
              phonefield.labelFunction = myLabelFunc;
              private function myLabelFunc(item:Object,column:DataGridColumn):String
              if (item.Info.Phone==undefined)
              {return null;}
              else
              {return item.Info.Phone;}
              Thanks guys.
