• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Conditional text in numbered lists
New Here ,
Jul 28, 2006 Jul 28, 2006
Hi All,
Could anyone tell me whether it is possible to apply conditional text to an entry in a numbered list and ensure that the entries remain consecutively numbered.
At the moment, after processing, the numbering does not alter leaving gaps in the numbered points.
Any advice would be appreciated.
Views
396
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Hi s-j-w. You certainly can but it depends on how you have applied your tags. Check the syntax of the list item. It should be something like <li style="x-condition: tag1;" class=kadov-P> where tag1 is the cbt name.
Votes
Translate
Translate
Report
Report
Engaged ,
Hi s-j-w,
Colum is absolutely right, you can apply conditional tags to numbered list and keep the sequence numbers. What I do is click on the list item three times in the wysiwyg editor and then right-click and select the conditional tag - that way you are sure to select the entire list item - if in doubt check the position onf the condition tag in the true code. One little gotcha is if you use the 'Restart Numbering' feature - kind of obvious I know but it still catches me out. When you restart numbering the number is hard coded and the sequences will not be automatically updated.
Kind Regards
Craig
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Hi Colum and Craig,
Thanks very much for your assistance. I now understand where I was going wrong and it works perfectly.
Regards
Steve
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
