2 Replies Latest reply on Oct 17, 2006 2:37 AM by Goo101
    calling a .exe from a Flash projector file
    Goo101
      I'm trying to call a .exe file from a Flash Projector file using the following code . . .
      fscommand("exec", "RipstationLite.exe" f="TouchScreen.rsf");
      The code "f="TouchScreen.rsf" points to an XML structured file which contains all the settings necessary for the RipstationLite.exe file to run automatically.
      Can I pass this 'settings' file like this, as a parameter, using the fscommand function?
      Any help would as always be much appreciated.
        • 1. Re: calling a .exe from a Flash projector file
          Goo101 Level 1
          Ok, Flash continues to infuriate me!
          I have removed the 'settings' file parameter from my fscommand call to see if my projector would at least launch the .exe file, as per the following code . . .
          fscommand("exec", "Ripstation Lite.exe");
          But nothing happened . . .
          I also tried another Windows .exe to see if it would work and again it failed to launch anything . . .
          fscommand("exec", "C:\Windows\System32\calc.exe");
          This .swf is wrapped by Zinc to produce a Projector .exe file but yet it fails to launch either .exe file! Why is this!?!?
          • 2. Re: calling a .exe from a Flash projector file
            Goo101 Level 1
            Just to clarify this issue, I got the call to the .exe working by publishing my Flash Projector file from Flash. Previously I had been using Zinc to produce the Flash Projector file and from some reason the fscommand function won't work in a Zinc compiled Flash Projector file . . . ?
