2 Replies Latest reply on Nov 15, 2006 6:37 AM by Newsgroup_User
    Maximise the exe
    ajeet.ghule
      When i publish my director mx application i create a exe in the application folder, but my problem is that exe is not of maximum size means the exe should be maximized.but when i maximise it the original stage goes to thelefthande side top corner.and the UI looks very ugly :(. I want to maximise my stage saize to the size of my desktop window.Is there any setting or a piece of code we need to write to achieve thi.Please let me know.
      thanks
        • 1. Re: Maximise the exe
          duckets Level 1
          If you always want your movie to be maximised to the monitor size, you can set the stage rect in your startmovie handler:
          [code]
          monitorWidth = _system.deskTopRectList[1].width
          monitorHeight= _system.deskTopRectList[1].height
          _movie.stage.rect = rect(0,0,monitorWidth,monitorHeight)
          [/code]
          The stage rect property represents the coordinates of the stage window on the user's monitor.
          hope this helps!
          - Ben
          • 2. Re: Maximise the exe
            Level 7
            If you ALWAYS want it full-screen, you can just set the Full Screen setting
            when you make the projector - no code needed. Also make sure Centered is
            checked, or it'll still end up in the upper left corner, though.
