Hi dick the flash and welcome to our community
This may be one of those "gray areas" where there really is
no "problem" per se.
Captivate 2 creates more files than Captivate 1 did. So it
may be necessary to take special measures to get things imported.
I'll be happy to outline what I know here, then you can possibly
ask your question in the Acrobat forum for further information. (I
have no knowledge of how Acrobat works)
A typical Captivate movie consists of four files. Let's
assume our project is named "Boffo".
* JavaScript file named standard.js
* HTML file named the same as your captivate project with an
extension of .HTM. In this case, it would be "Boffo.htm".
* The skin .SWF file. This file is named the same as your
captivate project, and has _skin.SWF appended. In this case, it
would be "Boffo_skin.swf".
* The movie .SWF file. This file is named the same as your
captivate project, and has the .SWF extension. In this case, it
would be "Boffo.swf".
So the Boffo.HTM page is launched. This page looks for the
standard.js file. It then loads up the Boffo_skin.swf file. The
Boffo_skin.swf file in turn loads up the Boffo.swf file.
As this is being somehow included as part of the Acrobat .PDF
file, I would think you could forego the .HTM and .JS files. This
would leave only the two .SWF files. And here is my stop. You will
need to hear from someone else whether .PDF content can use a .SWF
that calls a .SWF. And if so, how to go about getting them added to
the .PDF project.
Hopefully this has been helpful... Rick
