1 Reply Latest reply on Nov 15, 2006 9:10 PM by jpwrunyan
    Tabbing Not Working
    Ukie_239
      I have a parent application that loads a child application. The tabbing does not work at all on the child application. tabbing always goes back to the main application. I have set the tabChildren = true and TabIndex = 1 for the child object (then 2, 3 and so on for the other objects in the form I have turned off tabbing in the parent application (The menu where the application resides)
      I am sure their is a way to tab in Child Applications, but I am not sure what is blocking this from happening
        • 1. Re: Tabbing Not Working
          jpwrunyan Level 1
          First of all, depending on the browser there are bugs in the tabbing mechanism. If you are using MIE you are probably just out of luck until Adobe fixes the issues.
          If you want to check the code logic and make sure there's nothing wrong there, then execute the application's .swf on your computer file system (do not run it via a web browser).
