5 Replies Latest reply on Oct 16, 2006 1:45 PM by Newsgroup_User
    disable view html source code
    chinaeye Level 1
      Anyone know that how could I disable the html source code, so no one can right click and view source code.
      David
        • 1. Re: disable view html source code
          Stefan_K. Level 1
          Through javascript you can disable right-clicks.
          But there are easy ways around it (disable javascript), so if someone with basic knowledge want's to, he'll get the source.
          In fact, it is impossible to hide the source, the browser needs it to display, ...
          • 2. Re: disable view html source code
            Stefan_K. Level 1
            • 3. Re: disable view html source code
              The Albino
              Just encypt your source code. Coldfusion has an encyption mehtod which the server can understand but your users cannot. Word of wisdom, keep a backup because it will be encrypted to you too.
              • 4. disable view html source code
                dempster Level 1
                quote:
                That won't work. Once the encrypted cfm code is processed by the server, it is sent out as HTML. HTML code delivered to any browser has to be plain text. That's the whole point of an open system like this. Trying to prevent users from viewing the source doesn't really work.
                • 5. Re: disable view html source code
                  Level 7
                  David
                  There are methods that will disable the right click, but then what do
                  you do for those people that go to the 'View' menu and select 'Page
                  Source'? Or those who use the CTRL-U? Or those of us who have tools
                  like firebug that allow us to inspect the source both before and after
                  it has been rendered.
                  In other words you can not really do what you want to do, which is hide
                  your HTML source. The system just does not allow it at this time.
