2 Replies Latest reply on Nov 16, 2006 11:06 AM by McMaster05
    Start a projector on second monitor
    McMaster05 Level 1
      Hi!
      Is it possible to start an projector-exe on the second monitor?
      Or is there a setting when exporting to set that?
        • 1. Start a projector on second monitor
          duckets Level 1
          Yes, although I don't think there's a setting to do it in the Director user interface, it has to be done with lingo in the startMovie handler.
          If there's a second monitor attached, there will be a second 'rect' in _system.desktopRectList. To get it, use something like this.
          secondMonitor = _system.desktopRectList[2]
          'secondMonitor ' will now contain a rect which describes the pixel coordinates of the second monitor. You can then simply set the stage rect to this value, if you want the stage to fill the second monitor, like this:
          on startMovie
          _movie.stage.rect = secondMonitor
          end
          Or, if you want to keep your original stage size, but centre it in the second monitor, you'll need to do a few calculations, like this:
          on startMovie
          halfWidth = _movie.stage.sourceRect.width/2
          halfHeight = _movie.stage.sourceRect.height/2
          posLeft = secondMonitor.width-halfWidth
          posTop = secondMonitor.height-halfheight
          newRect = rect(posLeft,posTop,posLeft,posTop) + _movie.stage.sourceRect
          _movie.stage.rect = newRect
          end
          hope this helps!
          - Ben
          • 2. Re: Start a projector on second monitor
            McMaster05 Level 1
            Thanks Ben,
            you perfectly directed me in the correct Direction.
            It took some time until I realised, that I had to put it in a Moviescript, but now it works like a charm:
            on startMovie
            preloadmember
            myresult = the result
            if (the deskTopRectList).count="2" then
            moni_1 = (the deskTopRectList)[1]
            moni_2 = (the deskTopRectList)[2]
            moni_1_res = [(moni_1.width), (moni_1.height)]
            moni_2_res = [(moni_2.width), (moni_2.height)]
            if (moni_1_res = moni_2_res) then
            (the stage).rect = (the deskTopRectList)[2]
            else if (moni_1_res=[1600,1200]) then
            (the stage).rect = (the deskTopRectList)[1]
            else if (moni_2_res=[1600,1200]) then
            else
            end if
            else
            end if
            directToStage = TRUE
            end
