6 Replies Latest reply on Oct 30, 2006 12:10 PM by strifedk
    image loadClip memory usage problem
    strifedk
      I'm trying to create a gallery with built in slideshow. I load the images sequentially and then use the tween class to animate alpha values to shift between images. But when about 20-25 images are loaded, the memory usage get too high and the animations start to lag.
      I know i can remove the images again, but that means i have to load them all over again when the slideshow starts over again.
      I know there must be a solution 'cause i've seen galleries which loads images without increasing memory usage, and the images is cached after loading.
      Hope you can help me.
