7 Replies Latest reply on Oct 16, 2006 10:47 PM by kglad
    Converting Actionscript from 1.0 to 2.0
    ChuckRWD Level 1
      I am trying to convert Actionscript written in 1.0 to 2.0 for Flash 8. It is from a tsunami menu I downloaded off kirupa.com. There is no actions layer where al the actionscript is kept, and I have tried to convert it. I customized the menu and the tsunami effect works great, however, when I try to convert the actionscript, it is a mess. I am building a flash site, and don't want to have to import the swf containing my menu. If I do have to do that, will the fact that it is written in Actionscript 1 for Flash Player 4 have any bearing on the fact that I am making the site for Flash Player 8 or above? Also, how can I import just the text portion without any background (transparent background) in Flash so it lays neatly over the background I've created for the site? Although I have designed many flash headers and elements for my HTML websites, I am a newbie when it comes to Flash Site design and have a ton of questions, but this will get me started. Thank you for your time.
        • 1. Re: Converting Actionscript from 1.0 to 2.0
          do you mean when you publish using actionscript 2.0 your menu doesn't function correctly? can you find all the code?
          • 2. Re: Converting Actionscript from 1.0 to 2.0
            ChuckRWD Level 1
            The code is not in an "actions layer", it is attached to buttons and movie clips. Here is the code:
            colnum = "1";
            startnum = 1;
            endnum = 19;
            numberofItems = 19;
            mouseposX = int(getProperty("../dragscale", _x));
            mouseposY = int(getProperty("../dragscale", _y));
            i = startnum;
            m = startnum;
            filledSpace = 0;
            gapspace = 0;
            if (Number(myInit) == Number(FALSE)) {
            // on first run make an array of all the text Y Pos.
            while (Number(i)<=Number(endnum)) {
            set("textY" add i, getProperty ("text" add i, _y ) );
            i = Number(i)+1;
            i = startnum;
            myInit = TRUE;
            boundleft = getProperty ("../boundbox" add colnum, _x);
            boundright = boundleft + getProperty ("../boundbox" add colnum, _width) ;
            boundtop = getProperty ("../boundbox" add colnum, _y);
            boundbottom = boundtop + getProperty ("../boundbox" add colnum,_height);
            if (Number(mouseposX)>=Number(boundleft) and Number(mouseposX)<=Number(boundright) and Number(mouseposY)>=Number(boundtop) and Number(mouseposY)<=Number(boundbottom)) {
            myDif = (eval("textY" add i) ) - (mouseposY - boundtop);
            // percentage increase
            scaleAmount = 175-((myDif*myDif)/14);
            alphaAmount = 100-((myDif*myDif)/6);
            if (Number(alphaAmount)<50) {
            alphaAmount = 50;
            if (Number(scaleAmount)<100) {
            scaleAmount = 100;
            setProperty("text" add i, _xscale, scaleAmount);
            setProperty("text" add i, _yscale, scaleAmount);
            setProperty("text" add i, _alpha, alphaAmount);
            i = Number(i)+1;
            // *** add up total Y pixels taken by text ***
            while (Number(m)<=Number(endnum-1)) {
            filledSpace = filledspace + getProperty ( "text" add m, _height);
            m = Number(m)+1;
            // *** find total Y pixels not taken by text
            totalheight = getProperty ( "text" add endnum, _y) - getProperty ( "text" add startnum, _y);
            gapSpace = totalheight-filledspace;
            avgDistance = gapSpace/numberofitems;
            m = Number(startnum)+1;
            setProperty("text" add m, _y, (getProperty ( "text" add (m-1), _y) + getProperty ( "text" add (m-1), _height)) + avgdistance);
            set("watchheight" add m, getProperty ( "text" add m, _height));
            m = Number(m)+1;
            } else {
            // *** shrink text back when mouse rolls out
            i = startnum;
            if (int ( getProperty ("text" add i, _yscale ) ) >= 100) {
            // return scale back to original state
            setProperty("text" add i, _yscale, int ( getProperty ("text" add i, _xscale ) ) - 1);
            setProperty("text" add i, _xscale, int ( getProperty ("text" add i, _yscale ) ) -1);
            if ( getProperty ("text" add i, _y) < eval("textY" add i)) {
            // return y position back to original state
            setProperty("text" add i, _y, int ( getProperty ("text" add i, _y ) ) + 1);
            if ( getProperty ("text" add i, _y) > eval("textY" add i)) {
            setProperty("text" add i, _y, int ( getProperty ("text" add i, _y ) ) - 1);
            if ( getProperty ("text" add i, _Alpha) > 50) {
            setProperty("text" add i, _alpha, int ( getProperty ("text" add i, _alpha ) ) - 1);
            i = Number(i)+1;
            • 3. Re: Converting Actionscript from 1.0 to 2.0
              there are so many problems with that code i doubt i caught them all. but this will get you most of the way towards updating that code:
              • 4. Re: Converting Actionscript from 1.0 to 2.0
                ChuckRWD Level 1
                So, attach this code to frame 1 of the actions layer I will add to the top of the timeline? Also, if I load in this swf into the main swf, is there any way the background can be transparent so all I am loading is the text menu with no background to lay on top of the background in the main swf?
                • 5. Re: Converting Actionscript from 1.0 to 2.0
                  add that code to the same timeline in which it's currently located. there's no way to determine from that code how to use different paths.
                  the background of a loaded swf is always transparent when loaded into another swf.
                  • 6. Re: Converting Actionscript from 1.0 to 2.0
                    ChuckRWD Level 1
                    Although I don't get any errors now from the Actionscript when I change the publis settings to Flash Player 8, I also don't get the tsunami effect. I copied and pasted it where you said, and have played with it gor quite awile trying to get this guy to work, but no dice. Here is a link to grab the .fla file:
                    http://www.premieretans.com/FLA/tsunami.fla.
                    What is happening with the menu where it won't function in Flash Player 8?
