10 Replies Latest reply on Nov 22, 2006 1:10 PM by Nimfin
    HTTPService XML trouble
    Victor_K_Victor
      Hi. I use HTTPSevice to dynamicly load xml elements for mx:Tree. The xml is like
      <root>
      <row attr1="11" attr2="22".../>
      <row attr1="111" attr2="222".../>
      <row attr1="1111" attr2="2222".../>
      </root>
      And everything works perfect. But!!! 1 of 5 (more or less) times the error #1090:
      Microsoft Internet Explorer
      Error #1090: XML parser failure: element is malformed.
      occurs. I'm sure the xml is correct. I've checked it. But it's not small and attributes contain a long strings.
      Has anybody confronted with such problem?
        • 1. HTTPService XML trouble
          aBill
          I haven't seen such problem! How big is your xml? Can you also show me your result handler and the function which you call httpservice? Are you using HttpService tag or actionscript class? Are your httpservice instance is function's location variable? II saw a problem before in socket which a single varaible referencing all to start it. a = new Socket(); a.dosomething(); a = new Socket(); a.dosomething()....... etc. It turnws out when the player heap filled up. Garbage collector came in to destroy the non referenced socket.
          Thanks!
          William Chan
          • 2. Re: HTTPService XML trouble
            Victor_K_Victor Level 1
            There are mx:HTTPService tag
            <mx:HTTPService id="ntreeXML" resultFormat="text" useProxy="false" result="fHTTPServiceResult(event)" fault="fHTTPServiceFault2(event)"/>
            and
            <mx:Tree id="mainTree"
            change="changeEvt(event)"
            public function changeEvt(event:Event):void {
            ntreeXML.url = " http://localhost/TreeDoc2/bin/asp/pgTreeXML.asp?pSQLStr=" + event.currentTarget.selectedItem.@URLTREESQL.toString();
            ntreeXML.send();
            public var treeXMLInit2:XMLList;
            public function fHTTPServiceResult(event:ResultEvent):void
            treeXMLInit = new XMLList(event.result)}
            ****error happens here****
            Result of HTTPService is
            <_ROOT_>
            <RT isOnceLoaded="false" ID="ABC.1111111/11/11111.DOBLIST.1" IDHIGH="ABC.1111111/11/11111.DOBLIST" URLOUTPUT="Deafult.asp" LABEL="N: 1 AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA" ISFOLDER="1" URLTREE="Deafult.asp" URLTREESQL="select pkg_TREE_PROCEDURES.fDefault_PROCEDURE( '125','10.21.21.99','ABCD','GTD.STYLE.1','GTD.TREE_1_3_DOBLIST','[:FVAL.ND];[:FVAL.NDBASE ];[:FVAL.IDHIGH];[:FVAL.G32]','STRING;STRING;STRING;STRING','1111111/11/11111;X9;ABC.11111 11/11/11111.DOBLIST.1;1',NULL) TEXT_OUT from dual" URLOUTPUTSQL="select pkg_TREE_PROCEDURES.fDefault_PROCEDURE( '125','10.21.21.99','ABCD','GTD.STYLE.1','GTD.DOBLIST.1','[:FVAL.ND];[:FVAL.NDBASE];[:FVA L.IDHIGH];[:FVAL.G32]','STRING;STRING;STRING;STRING','1111111/11/11111;X9;ABC.1111111/11/1 1111.DOBLIST.1;1',NULL) TEXT_OUT from dual" >
            </RT>
            nearly 200 RT tags
            </ROOT>
            It is correct. xml is 160KB. If I load xml from local xml file, there is no problems. But if I take it from ASP page, it works, but sometimes the problem (error #1090) happens.
            I used URLLoader class instead of HTTPService tag, but the result was the same.
            Thank you for your answer
            Victor
            • 3. HTTPService XML trouble
              aBill Level 1
              Since it works in static page, it might be the asp problem. Can you use a http sniffer to capture the asp output? When the problem arises, you can verify the xml.
              William Chan
              • 4. Re: HTTPService XML trouble
                Hi. Thank you William for your answers. It seems I've found a way to manage the problem. But I haven't understood the reason. I simply catch an error and use HTTPService send() again until xml loads correctly. The problem is not in ASP.
                Victor K.
                • 5. HTTPService XML trouble
                  SalimChujfi
                  Hi Bill
                  Hi Victor
                  I do have a similar problem. Im sending the result from a HTTPService directly to an arrayCollection, everything works fine when my XML has more than one object. If the XML has only one node I get immediately a run time error saying
                  "Typumwandlung fehlgeschlagen: mx.utils::ObjectProxy@b614ac1 kann nicht in mx.collections.ArrayCollection umgewandelt werden."
                  which means that the objectProxy returned can not be converted into an arrayCollection. I have checked during the last 2 days the XML and it is completely correct.
                  I can catch without any problem the result of the HTTPService when I use the mehtod .lastresult, however I need to manipulate the information using an Array therefore i',m trying to use the arrayCollection structure.
                  Have you any idea what could be the problem ?
                  • 6. Re: HTTPService XML trouble
                    aBill Level 1
                    How your xml look like? Does your xml contain repeating element?
                    example
                    <mydata>
                    <name>abc</name>
                    <name>abc</name>
                    <name>abc</name>
                    </mydata>
                    lastResult.mydata.name is an array. If name just appears one, it won't be converted as array. I am not sure it is the problem or not.
                    William Chan
                    • 7. Re: HTTPService XML trouble
                      Nimfin
                      Hi!
                      I have the same problem with URLLoader class.
                      I use it that way:
                      var request:URLRequest = new URLRequest(" http://localhost/kinoflex.php");
                      var loader:URLLoader = new URLLoader();
                      public function send(datasend:String):void {
                      request.contentType = "text/xml";
                      request.method = URLRequestMethod.POST;
                      try {
                      request.data = datasend;
                      loader.load(request);
                      } catch (error:ArgumentError) {
                      Alert.show('An ArgumentError has occurred.','Error!');
                      } catch (error:SecurityError) {
                      Alert.show('A SecurityError has occurred.','Error!');
                      public function onInit():void {
                      loader.addEventListener('complete',receive);
                      public function receive(evtObj:Event):void {
                      var resXML:XML;
                      trace('Data format: '+loader.dataFormat);
                      trace('Bytes loaded: '+loader.bytesLoaded);
                      trace('Bytes total: '+loader.bytesTotal);
                      trace(loader.data);
                      resXML = XML(loader.data); // Error occures here
                      And the traces (repeating items skipped, xml formatted for convenience):
                      Data format: text
                      Bytes loaded: 7713
                      Bytes total: 7713
                      <resp>
                      <cmd>get_libs</cmd>
                      <res>ok</res>
                      <movie>
                      <item><id>285</id><name>Адреналин</name><lid>976</lid></item>
                      [REPEATING_ITEMS]
                      <item><id>439</id><name>Прощальный поцелуй</ TypeError: Error #1088: The markup in the document following the root element must be well-formed.
                      at kinoadmin/receive()[C:\pers\projects\flex\kinoadmin\kinoadmin.mxml:459]
                      at flash.events::EventDispatcher/flash.events:EventDispatcher::dispatchEventFunction()
                      at flash.events::EventDispatcher/dispatchEvent()
                      at flash.net::URLLoader/flash.net:URLLoader::onComplete()
                      name><lid>1688</lid></item>
                      <item><id>434</id><name>Свидание моей мечты</name><lid>1696</lid></item>
                      [REPEATING_ITEMS]
                      <item><id>433</id><name>Эскадрилья Лафайет</name><lid>1692</lid></item>
                      </movie>
                      </resp>яяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяя`
                      As we can see, the error goes before the trace outputs all the text. May be function XML(loader.data) starts before all the response passed to loader.data? And strange symbols attached to the end of file. Every time they are different. I have no such strings in my script. I've tested the response of my script, addresing it directly in firefox - the script returns valid XML without any trailing wierd symbols.
                      The size of received file is 7 714 bytes. And in this case error came on 7092 bytes.
                      I will be glad if u find my mistake or solution of this problem.
                      Thanks!
                      • 8. Re: HTTPService XML trouble
                        Nimfin Level 1
                        Temporarly solved the problem this way:
                        var resXML:XML;
                        if (loader.data.substring(loader.data.length-7) != '</resp>') {
                        var pos:int = loader.data.indexOf('</resp>');
                        loader.data = loader.data.substring(0,pos+7);
                        • 9. Re: HTTPService XML trouble
                          Nussy1664
                          quote:
                          Originally posted by: aBill
                          example
                          <mydata>
                          <name>abc</name>
                          <name>abc</name>
                          <name>abc</name>
                          </mydata>
                          William Chan
                          This is exactly the problem I have. Any suggestions?
                          • 10. Re: HTTPService XML trouble
                            Nimfin Level 1
                            Yes XML has repeating elements, but I think the problem is not here.
                            It will be very interesting to see developers comments.
