2 Replies Latest reply on Nov 14, 2006 7:57 AM by RustyT
    Movieclip, Capturing Mouse Click On Entire Stage
    RustyT
      I made a 2-state button within a project (completely at designtime) using a movieclip. I change the state (and look) of the button by toggling between frame 1 and 2. The problem is...
      Even though the clip I created (and saved in the library) is small, the onMouseUp event is captured by the movieclip no matter where I click on the stage. Any thoughts?
      Here's the code...
      This is in frame 1
      _root.Status_Append("code running on frame 1"); // display status info (debugging)
      this.base_off.onMouseUp = function() {
      _root.Status_Append("base_off.onMouseUp"); // display status info (debugging)
      gotoAndStop(2);
      stop();
      This is in frame 2
      _root.Status_Append("code running on frame 2"); // display status info (debugging)
      this.base_on.onMouseUp = function() {
      _root.Status_Append("base_on.onMouseUp"); // display status info (debugging)
      gotoAndStop(1);
