2 Replies Latest reply on Oct 17, 2006 1:06 PM by Sanctified_Design
    Can't access movieclip...
    Sanctified_Design
      I created a script that duplicates a movieclip several times based on the number of nodes an external XML file has. It seems that I can't access the movieclips or change their properties or instances or the properties and instances of subsequent movieclips within them. When I try to access them I get "undefined" while tracing it. Sorry about the amount of code, I don't want to leave any of the variables out... Any help would be greatly appreciated! Thanks.
        • 1. Re: Can't access movieclip...
          digitellinc Level 1
          does the pCamera0 movie clip exist ?
          quote:
          duplicateMovieClip("pCamera0", pCamera, 10+n);
          If it does you are duplicating it with a movie clip with the exact same name.
          If it doesn't you are duplicating a movie that doesn't exist in the first place.
          • 2. Re: Can't access movieclip...
            Sanctified_Design Level 1
            yes it does... when the loop goes through the first time... it overwrites it, which is what I wanted. I should also ad that the set _x and _y properties do work so everything is formated where I want it... which is weird because when I try to access it to get a movieclip within it, it say's it's undefined. I should also add that I've been working on this problem for about the last 5 hours straight, so I'm sure I'm missing something stupid!
