0 Replies Latest reply on Nov 13, 2006 2:47 PM by NUMB-LOCK
    Sending a ByteArray of rich text to a Java Web Service via WebService component
    NUMB-LOCK Level 1
      I was able to send and receive rich text (HTML formatted txt) intact
      via a Java web service using Weblogic 9.2. Creating a web service in
      Weblogic 8.1 is more difficult so I opted for this route. Regardless
      what back end implementation you are using, in order to keep rich text
      intact is to send it via a ByteArray in flex. And with the web service
      (possibly using Coldfusion), be sure that the input parameter and
      return types that the WSDL creates are "base64Binary."
      Creating a web service in Weblogic 9.2 is pretty easy. If you are
      using this app server then the 9.2 docs on Web Services is how I
      created my back end. My web service simply accepts a byte[] as a
      parameter and returns it.
      public class HelloWorldImpl {
      public byte[] getBytes(byte[] bAry) {
      return bAry;
      In flex:
      [Bindable]
      private var bAryObj:ByteArray = new ByteArray();
      [Bindable]
      private var txtResult:String;
      public function sendingBytes(event:Event) {
      // inputTxt is a HTML formatted string a.k.a rich text
      bAryObj.writeUTF(inputTxt);
      // call webService
      wsData.getBytes.send();
      public function webSvcHandler(event:ResultEvent) {
      var b:ByteArray = new ByteArray();
      b.position = 0; // make sure you read the array from the beginning
      // use binding of txtResult in some component as {txtResult}
      txtResult = b.readUTF() as String;
      mxml - be sure mxml parameter names match exactly the web service
      parameter names:
      <mx:WebService id="wsData"
      wsdl="yourWsdl"
      result="webSvcHandler(event)"
      fault="faultHandler(event)"
      <mx:operation name="getBytes">
      <mx:request xmlns="">
      <bAry>{bAryObj}</bAry>
      </mx:request>
      </mx:operation>
      </mx:WebService
      I used a Button component to call sendingBytes() via the click event.
      Hope I didn't forget anything...and hope this helps.
      Bob I.
