2 Replies Latest reply on Jan 22, 2009 6:04 AM by Newsgroup_User
    Referencing objects in a Repeater
    webquorning
      Hi all,
      I have a problem referencing objects created by a repeater-component with data from an external XML-file.
      For instance, for each node i repeate from the XML-datasource, i would like a textfield with a Slider-component and a button. The button should be enabled only when the Slider-component has changed (see attached code).
      But when i use the change-property on the Slider-component to set the button to be "enabled", nothing happens.
      My guess is that I don't reference the button correctly. Any help?
