2 Replies Latest reply on Oct 16, 2006 12:44 PM by TILOTOHA
    Importing a Video Encoder file into RoboHelp HTML
    TILOTOHA
      I have imported a video encoder file which has the .swf extension into RoboHelp HTML. However whenever I generate the project then view the video, nothing displays except the shell that shows there is something there when you mouse over. The pop-up message says "Click to activate and use this control." I do that and nothing happens. Please help.
      Thanks...
        • 1. Re: Importing a Video Encoder file into RoboHelp HTML
          RoboWizard Level 4
          Hi TILOTOHA and welcome to our community
          I'm guessing here that your use of terminology is just a bit off and you are referring to a Flash file generically as a "video encoder" file. Or is this a Flash created file that actually does something to encode videos when it is run?
          My guess is the former. So what are you using to create this file? It's not uncommon to see different applications create multiple files that must be used in order to make the Flash animation work. So I'm guessing that you are simply missing some of the components that are needed.
          Cheers... Rick
          • 2. Re: Importing a Video Encoder file into RoboHelp HTML
            TILOTOHA Level 1
            Thanks for the quick reply Rick as you can see I was checking in every 10 minutes. ;o)
            The name of the application that I created the video file in is called Flash 8 Video Encoder. After creating the file I imported it into RoboHelp. So perhaps there are some coponents missing. Not as cut and dry as I thought. Suggestions???
