Is it possible to run cold fusion code in .html pages? I am
days from going live on a big project and the client is suddenly
freaking out over the fact that her urls will not be ".html"
But it is possible to have ColdFusion run html pages.
Sorry the headache is making me a bit of a smart aleck this
morning.
To do this you will need control of your server. This is not
something
many Hosting companies will do on a shared box. But you can
go into the
IIS manager (I don't know the Apache equivalent, but I'm sure
it is
there) and associate the .htm and|or .html extension to the
ColdFusion
process. Then the webserver will and all such pages to
ColdFusion which
will process them just as it does .cfm pages.
If your webserver gives you the capability to change it
executable path (example: .html files run through xxxx.dll) and
just have .html files use the coldfusion dll, then theoredically it
should work.
I admit it could be a drastic change since you are working
with shared hosting, but nevertheless it is an idea.
