0 Replies Latest reply on Sep 18, 2006 11:40 AM by Newsgroup_User
    Re: mxmlc compile problem
    Level 7
      What do you have set for the library-path in your config file? It looks like
      you are referencing a copy of the flex-config.xml file that has been placed
      in the bin directory?
      I would recommend:
      - if there is no need to load a specific config file then just call >
      mxmlc -file-specs {file}
      - if there is something that you want to specifically set, but don't need to
      reset every setting then in the custom config file just add the setting that
      you want different and call > mxmlc -load-config+=myconfig.config {file}
      "jrief" <webforumsuser@macromedia.com> wrote in message
      news:eeml0v$jmg$1@forums.macromedia.com...
      > I'm receiving the following errors when I attempt to compile a flex
      > 2application using the mxmlc command line compiler:
      > C:\Program Files\Adobe\Flex Builder 2\Flex SDK 2\bin>cmd /C
      > mxmlc -file-specs
      > C:
      > \cc_views\jrief_Prototype\Prototype\apps\DataWarehouse\source\mxml\apps\CycleTim
      > eUI.mxml -load-config flex-config.xml
      > Loading configuration file C:\Program Files\Adobe\Flex Builder 2\Flex SDK
      > 2\bin\
      > flex-config.xml
      > Error: Unable to resolve a class for ResourceBundle: messaging.
      > Error: Unable to resolve a class for ResourceBundle: rpc.
      > Error: Unable to resolve a class for ResourceBundle: utils.
      > Error: Unable to resolve a class for ResourceBundle: data.
      > The compile seems to be looking for the .properties files for the 4
      > missing
      > bundles. I do not find the .properties file anywhere on my system. Any
      > clues
      > where they might be?
