6 Replies Latest reply on Sep 20, 2006 11:10 PM by Hangring
    What happened?
    Hangring
      if ("") {
      trace("\"\"");
      Or
      if ('') {
      trace("''");
      output "" or ''.
      But, 'while' is all right!
      I don't know what happended?
        • 1. Re: What happened?
          Level 7
          Hangring,
          > if ("") {
          > trace("\"\"");
          > Or
          > if ('') {
          > trace("''");
          > output "" or ''.
          Okay, I'm with you so far.
          That's where I lose you. What are you asking?
          David Stiller
          Adobe Community Expert
          Dev blog, http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: What happened?
            Level 7
            > if ("") {
            Why would you write such a thing?
            Jeckyl
            • 3. Re: What happened?
              NSurveyor Level 2
              I thinkn the OP is asking why "" evaluates to true in an if statement, but not in a while statement. Example:
              if(''){
              trace('indeed');
              the trace WILL occur. But if you do:
              while(''){
              trace('indeedy');
              nothing happens.
              Well to me, it looks like some compiler sort of thing. When it sees if('') it simply removes it, but keeps the code that would be in the braces. But if you did:
              x = '';
              if(x){
              trace("hi");
              hi would not be traced. So, if you don't have if('') it will evaluate x using the Boolean conversion function, and thus Boolean('') = false
              • 4. Re: What happened?
                lol, i'm with jeckyl on this one.
                • 5. Re: What happened?
                  ggshow Level 2
                  ok, let me guess... what Hangring want to know is:
                  empty string / double quot ("") return TRUE or FALSE
                  // if convert "" to boolean
                  a = Boolean("");
                  trace(a); //it return false
                  while ("") {
                  // statement here doesn't works, it is normal
                  if ("") {
                  // statement here works, why?
                  OK, the point is...
                  for IF and WHILE statements, the condition you can put inside the () supposed to be Boolean, but not a string :-)
                  • 6. What happened?
                    Hangring Level 1
                    Yes. When i show all that the value return 'false', follow:
                    1) false or !true
                    2) undefined
                    3) null
                    4) "" or ''
                    5) 0 or 0.0
                    6) undefined variable
                    When i write:
                    if (undefined) {
                    // don't works
                    Or
                    var a = undefined;
                    if (a) {
                    // don't works
                    And so on, then:
                    var a = "";
                    if (a) {
                    // don't works
                    But:
                    if ("") {
                    // works
                    In JavaScript:
                    var a = "";
                    if (a) {
                    // don't works
                    Or
                    if ("") {
                    // don't works
                    My question is that the "" or '' what meant that in if statement.
                    Thanks.
