Well, I just got done with Adobe support (After 4 hours of
telephone calls) and her is the problem & fix/work around:
With the X5.2 Update and recent MS Explorer security patches,
this problem occurs with Flash Layouts specificly due to "Active
Content".
When compiling an output, RoboHelp adds a "Mark of the
Internet" tag just below the Doctype statement in the outputed HTML
code of the page. This is the problem, this extra tag that is
added. If you look at the code posted above, just after the Doctype
statement, there is a new tag there (I missed it too). I copied the
code of the compiled version below:
<!doctype HTML public "-//W3C//DTD HTML 4.0
Frameset//EN">
<!-- saved from url=(0026)
http://www.macromedia.com/
<html>
Work Arounds:
1) Go into every page of the compilied outputs (I plan on
using a multi-find & replace tool) to the source code level and
delete the "Mark fo the Internet" tag (This is the "saved from url"
line shown above.
2) Use the WebHelp Single Source Layout. It does not have
this problem, so no Flash.
3) Revert your copy of RoboHelp Office X5.0.2 back to X5.0.1
via the Add/Remove function of Windows in the Control Panel.
Hope this helps anyone else you runs into this issue.
