5 Replies Latest reply on Sep 20, 2006 9:01 AM by
    Some sort of scroll bar?
      How can i put some sort of scroll bar in my flash, say i have alot of text but dont want to make my flash a crazy size, so you can scroll down and see more.
      Any help will be greatly apprichiated
        • 1. Re: Some sort of scroll bar?
          Level 7
          l3lade,
          You didn't mention what version of Flash you're using. Have you checked
          out the UIScrollBar Component in the Components panel?
          David Stiller
          Adobe Community Expert
          Dev blog, http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: Some sort of scroll bar?
            Damon Edwards Level 3
            you can create a dynamic text field and put all your text in it. say you name the text field "AboutMe_txt"...create two buttons, one for up, and one for down. attatch this code to the down button
            on(release)
            AboutMe_txt.scroll = AboutMe_txt.scroll +5;
            and this to the up button
            on(release)
            AboutMe_txt.scroll = AboutMe_txt.scroll -5;
            replace "AboutMe_txt" with whatever you name your instance
            • 3. Re: Some sort of scroll bar?
              luminousnerd
              I hope I'm not stealing the topic,
              But I am curious how you would do it if you had to put images, text, bullets, etc.
              • 4. Re: Some sort of scroll bar?
                Level 7
                luminousnerd,
                You are, of course. ;)
                You would use HTML text in that text field, and use the <img> tag and
                other *very limited* HTML tags supported by Flash (search "supported HTML
                tags" in the Help to see exactly which ones).
                David Stiller
                • 5. Re: Some sort of scroll bar?
                  Flash 8
                  and thanks that did the job :P
