0 Replies Latest reply on Sep 22, 2006 5:07 AM by Newsgroup_User
    Re: PDF to FlashPaper 2
    Level 7
      I am also developing a similar kind of library application wher I have arnd
      doc_name and doc_id in DB. My requirement is to design a CF template which
      reads doc_id passed to it via form, query the DB for the doc_name (doc_name
      can be .xls / .pdf / .doc) and render the fileto FlashPaper.
      I used
      <cfdocument format="FlashPaper" src="sample.pdf" mimetype="application/pdf">
      </cfdocument>
      It renders the flashpaper but the text in it is junk. The text look like a
      .pdf file opend in notepad.
      Any help would be appreciated.
      Darshan Oza. Technical Associate Automated Workflow Pvt. Ltd. 14/1, MEG
      Officers' Colony, Banaswadi Main Road, Bangalore - 56 00 33. ) : +91 93438
      68628 ( : 080 2546 7241 Ê : 080 2549 0576 * : darshan@aworkflow.com
      Transforming the Way People Work.
      ----- Original Message -----
      Newsgroups: macromedia.coldfusion.advanced_techniques
      Sent: Tuesday, September 12, 2006 9:47 PM
      Subject: PDF to FlashPaper 2
      hi all,
      I'm trying to build an application over Coldfusion that implements a
      conversion from a pdf into a Flashpaper document. The only way I had found
      to
      do that is using FlashpaperConnect.dll that comes with Contribute 3. My
      problem
      is that I need to run ColdFusion over Linux and Contribut does not have a
      Linux
      version.
      Question:
      Is there any library for linux with the same function of
      FlashpaperConnect.dll?
      Anybody know another way to implement this kind of conversion that could
      work
      in linux?
      FerSantaFe
