1 Reply Latest reply on Sep 25, 2006 7:33 AM by knallore_adobe
    Problems configuring FDS with Hibernate
    MalengaTiger
      I'm trying to configure Flex Data Services with Hibernate on the back end and I'm running into
      these problems as shown below. Any pointers to solve these would be highly appreciated.
      Thanks in anticipation!
      Aubrey M.
      Config: Windows XP
      FDS 2
      Integrated JRun4
      Entries in data-management-config.xml
      <?xml version="1.0" encoding="UTF-8"?>
      <service id="data-service"
      class="flex.data.DataService"
      messageTypes="flex.data.messages.DataMessage">
      <adapters>
      <adapter-definition id="actionscript" class="flex.data.adapters.ASObjectAdapter" default="true"/>
      <adapter-definition id="java-adapter" class="flex.data.adapters.JavaAdapter"/>
      </adapters>
      <default-channels>
      <channel ref="my-rtmp"/>
      </default-channels>
      <destination id="BohaUser" channels="my-rtmp">
      <adapter ref="java-adapter" />
      <properties>
      <!-- <use-transactions>true</use-transactions> -->
      <source>flex.data.assemblers.HibernateAssembler</source>
      <scope>application</scope>
      <metadata>
      <identity property="id"/>
      <many-to-one property="establishment"
      destination="Establishment" lazy="true" />
      <many-to-one property="userRole"
      destination="UserRole" lazy="true" />
      </metadata>
      <network>
      <!-- <session-timeout>20</session-timeout> -->
      <paging enabled="true" pageSize="10" />
      <throttle-inbound policy="ERROR" max-frequency="500"/>
      <throttle-outbound policy="REPLACE" max-frequency="500"/>
      </network>
      <server>
      <hibernate-entity>boha.db.BohaUser />
      <update-conflict-mode>PROPERTY/>
      <delete-conflict-mode>OBJECT/>
      <fill-configuration>
      <use-query-cache>false/>
      <allow-hql-queries>true/>
      </fill-configuration>
      </server>
      </properties>
      </destination>
      <!-- End of Hibernate destination -->
      <destination id="Establishment" channels="my-rtmp">
      <properties>
      <metadata>
      <many-to-one property="owner"
      destination="Owner" lazy="true" />
      <many-to-one property="province"
      destination="Province" lazy="true" />
      </metadata>
      <network>
      </network>
      <server>
      <hibernate-entity>boha.db.Establishment</hibernate-entity>
      <update-conflict-mode>PROPERTY</update-conflict-mode>
      <delete-conflict-mode>OBJECT</delete-conflict-mode>
      <use-query-cache>false</use-query-cache>
      <allow-hql-queries>true</allow-hql-queries>
      </server>
      </properties>
      </destination>
      <destination id="UserRole" channels="my-rtmp">
      <properties>
      <metadata>
      </metadata>
      <network>
      </network>
      <server>
      <hibernate-entity>boha.db.UserRole</hibernate-entity>
      </server>
      </properties>
      </destination>
      Output of integrated JRun4 startup
      9/18 12:52:26 info No JDBC data sources have been configured for this server (see jrun-resources.xml)
      09/18 12:52:26 info JRun Web Server listening on *:8700
      09/18 12:52:26 info Deploying web application "Flex Default Web Application" from: file:/C:/aaa-fds/jrun4/servers/default/default-war/
      09/18 12:52:26 user JSPServlet: init
      09/18 12:52:27 info Deploying web application "Boha Online Reservations" from: file:/C:/aaa-fds/jrun4/servers/default/flex/
      09/18 12:52:28 user JSPServlet: init
      09/18 12:52:29 user FlexMxmlServlet: init
      09/18 12:52:30 user FlexMxmlServlet: Starting Adobe Flex Web Tier Compiler
      09/18 12:52:30 user FlexMxmlServlet: Adobe Flex Web Tier Compiler Build: 143451
      09/18 12:52:30 user MessageBrokerServlet: init
      09/18 12:52:38 error Could not pre-load servlet: MessageBrokerServlet
      flex.messaging.config.ConfigurationException: Unused tags in <properties> found. Please fix them before continuing:
      '/server/delete-conflict-mode' in destination with id: 'UserRole' from file: data-management-config.xml
      '/server/update-conflict-mode' in destination with id: 'UserRole' from file: data-management-config.xml
      '/server/fill-configuration' in destination with id: 'UserRole' from file: data-management-config.xml
      '/server/hibernate-entity' in destination with id: 'UserRole' from file: data-management-config.xml
      '/server/delete-conflict-mode' in destination with id: 'Establishment' from file: data-management-config.xml
      '/server/update-conflict-mode' in destination with id: 'Establishment' from file: data-management-config.xml
      '/server/fill-configuration' in destination with id: 'Establishment' from file: data-management-config.xml
      '/server/hibernate-entity' in destination with id: 'Establishment' from file: data-management-config.xml
      '/server/delete-conflict-mode' in destination with id: 'BohaUser' from file: data-management-config.xml
      '/server/update-conflict-mode' in destination with id: 'BohaUser' from file: data-management-config.xml
      '/server/fill-configuration' in destination with id: 'BohaUser' from file: data-management-config.xml
      '/server/hibernate-entity' in destination with id: 'BohaUser' from file: data-management-config.xml
      at flex.messaging.config.MessagingConfiguration.reportUnusedProperties(MessagingConfiguratio n.java:432)
      at flex.messaging.MessageBrokerServlet.init(MessageBrokerServlet.java:110)
      at jrun.servlet.WebApplicationService.loadServlet(WebApplicationService.java:1200)
      at jrun.servlet.WebApplicationService.preloadServlets(WebApplicationService.java:791)
      at jrun.servlet.WebApplicationService.postStart(WebApplicationService.java:293)
      at jrun.deployment.DeployerService.initModules(DeployerService.java:711)
      at jrun.deployment.DeployerService.createWatchedDeployment(DeployerService.java:242)
      at jrun.deployment.DeployerService.deploy(DeployerService.java:430)
      at jrun.deployment.DeployerService.checkWatchedDirectories(DeployerService.java:179)
      at jrun.deployment.DeployerService.run(DeployerService.java:891)
      at jrunx.scheduler.SchedulerService.invokeRunnable(SchedulerService.java:230)
      at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:428)
      at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
      09/18 12:52:39 user FlexInternalServlet: init
      09/18 12:52:39 info Deploying web application "Flex Admin Web Application" from: file:/C:/aaa-fds/jrun4/servers/default/flex-admin/
      09/18 12:52:39 user JSPServlet: init
      09/18 12:52:40 user MessageBrokerServlet: init
      09/18 12:52:40 info Deploying web application "Flex Data Services Samples" from: file:/C:/aaa-fds/jrun4/servers/default/samples/
      09/18 12:52:41 user JSPServlet: init
      09/18 12:52:43 user FlexMxmlServlet: init
      09/18 12:52:44 user FlexMxmlServlet: Starting Adobe Flex Web Tier Compiler
      09/18 12:52:44 user FlexMxmlServlet: Adobe Flex Web Tier Compiler Build: 143451
      09/18 12:52:44 user MessageBrokerServlet: init
      09/18 12:52:46 user FlexSwfServlet: init
      09/18 12:52:46 user FlexInternalServlet: init
      09/18 12:52:46 info Deploying enterprise application "JRun 4.0 Internal J2EE Components" from: file:/C:/aaa-fds/jrun4/lib/jrun-comp.ear
      09/18 12:52:46 info Deploying EJB "JRunSQLInvoker" from: file:/C:/aaa-fds/jrun4/lib/jrun-comp.ear
