5 Replies Latest reply on Oct 30, 2006 5:40 PM by MikerRoo
    CVS & CFMX & CFEXECUTE doens´t work
    alexd1979 Level 1
      Hello,
      I try to develop a CF CVS Management Console but at the beginning, the Basics doesn´t work.
      In the Windows command shell the command cvs checkout -d ttt cftest works fine. But the same Procedure in CFEXECUTE doesn´t work, nothing happens and the cftry said everything ok during the execution.
      I have a CFMX 6.1 and Tortoise CVS installed on a Windows XP Professional with all patches.
      Can somebody help me?
      My test.cfm:
        • 1. Re: CVS & CFMX & CFEXECUTE doens´t work
          MikerRoo Level 1
          Your code looks correct (assuming you've got a french version of windows -- otherwise it's FUBAR ;-).
          I''ve never been able to get cfexecute to work with a zero timeout (the default).
          Add timeout="60" to the cfexecute statement.
          Also, what account are the CF services running under?
          • 2. Re: CVS & CFMX & CFEXECUTE doens´t work
            alexd1979 Level 1
            Hello,
            No, it is a German Version of Windows.
            CF run with Local System Account
            • 3. Re: CVS & CFMX & CFEXECUTE doens´t work
              MikerRoo Level 1
              Should work.
              What happens when you run the attached?
              • 4. Re: CVS & CFMX & CFEXECUTE doens´t work
                lowercasem Level 1
                Hi! i'm looking to do the same and am having the same issue.... here's what happens when i run that
                ALLUSERSPROFILE=C:\Documents and Settings\All Users
                CLASSPATH=.;C:\Program Files\Java\jre1.5.0_06\lib\ext\QTJava.zip
                CommonProgramFiles=C:\Program Files\Common Files
                COMPUTERNAME=STATION-8
                ComSpec=C:\WINDOWS\system32\cmd.exe
                FP_NO_HOST_CHECK=NO
                NUMBER_OF_PROCESSORS=2
                OS=Windows_NT
                Path=C:\JRun4\servers\cfusion\cfusion-ear\cfusion-war\WEB-INF\cfusion\lib;C:\JRun4\servers \cfusion\cfusion-ear\cfusion-war\WEB-INF\cfusion\jintegra\bin;C:\JRun4\servers\cfusion\cfu sion-ear\cfusion-war\WEB-INF\cfusion\jintegra\bin\international;C:\JRun4\verity\k2\_nti40\ bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\ATI Technologies\ATI Control Panel;;C:\Program Files\Microsoft SQL Server\80\Tools\BINN;C:\Program Files\QuickTime\QTSystem\
                PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
                PROCESSOR_ARCHITECTURE=x86
                PROCESSOR_IDENTIFIER=x86 Family 15 Model 4 Stepping 3, GenuineIntel
                PROCESSOR_LEVEL=15
                PROCESSOR_REVISION=0403
                PROMPT=$P$G
                QTJAVA=C:\Program Files\Java\jre1.5.0_06\lib\ext\QTJava.zip
                SystemDrive=C:
                SystemRoot=C:\WINDOWS
                TEMP=C:\WINDOWS\TEMP
                TMP=C:\WINDOWS\TEMP
                USERPROFILE=C:\Documents and Settings\NetworkService
                VERITY_CFG=C:\JRun4\verity\k2\common\verity.cfg
                windir=C:\WINDOWS
                • 5. Re: CVS & CFMX & CFEXECUTE doens´t work
                  MikerRoo Level 1
                  That you got that output means that cfexecute is working.
                  Now select programs can still be blocked by the default configuration of Windows XP (and maybe 2003).
                  USUALLY, you can clear this issue as follows:
                  1. Open the Services control panel.
                    (Windows control panel -> Administrative Tools -> Services)
                  2. Scroll down and select "ColdFusion MX 7 Application Server".
                  3. Right-click and open the properties.
                  4. Select the "Log On" tab.
                  5. Check "Allow service to interact with desktop".
                  6. Close the properties dialog.
                  7. Restart the "ColdFusion MX 7 Application Server" service.
