0 Replies Latest reply on Sep 20, 2006 8:24 AM by hkk
    CFDataServicesAdapter not starting - cfcrm
    hkk
      i have problems with the cf_crm sample from http://www.adobe.com/devnet/flex/articles/coldfusionflex_part2_02.html
      my flex server is not starting with the coldfusion-dao adapter.
      i've made all the changes in the config files, but flex start without the doa adapter, but there are different error messages:
      compiled version:
      [MessagingError message='Unknown destination 'cfcompany' for service with id 'data-service'.']
      server-version:
      Error invoking fill.method "fill" for destination cfcompany; Connection refused to host: 192.168.0.234; nested exception is: java.net.ConnectException: Connection timed out: connect
      heres the console output:
      Starting Macromedia JRun 4.0 (Build 106363), default server
      Flex OEM License for JRun enabled
      20/09 17:04:24 warning D:\fds2\jrun4/lib/license.properties kann nicht ge÷ffnet
      werden.
      20/09 17:04:25 info JRun Naming Service listening on *:2907
      20/09 17:04:25 info No JDBC data sources have been configured for this server (s
      ee jrun-resources.xml)
      20/09 17:04:25 info JRun Web Server listening on *:8700
      20/09 17:04:25 info Deploying enterprise application "JRun 4.0 Internal J2EE Com
      ponents" from: file:/D:/fds2/jrun4/lib/jrun-comp.ear
      20/09 17:04:25 info Deploying EJB "JRunSQLInvoker" from: file:/D:/fds2/jrun4/lib
      /jrun-comp.ear
      Server default ready (startup time: 2 seconds)
      20/09 17:04:25 info Deploying web application "Flex Default Web Application" fro
      m: file:/D:/fds2/jrun4/servers/default/default-war/
      20/09 17:04:25 user JSPServlet: init
      20/09 17:04:26 info Deploying web application "Flex Data Services" from: file:/D
      :/fds2/jrun4/servers/default/flex/
      20/09 17:04:26 user JSPServlet: init
      20/09 17:04:26 user FlexMxmlServlet: init
      20/09 17:04:26 INFO Loading configuration file D:\fds2\jrun4\servers\default\fle
      x\WEB-INF\flex\flex-webtier-config.xml
      x\WEB-INF\flex\flex-config.xml
      20/09 17:04:27 user FlexMxmlServlet: Starting Adobe Flex Web Tier Compiler
      20/09 17:04:27 user FlexMxmlServlet: Adobe Flex Web Tier Compiler Build: 143451
      20/09 17:04:27 user MessageBrokerServlet: init
      20/09 17:04:27 user FlexSwfServlet: init
      20/09 17:04:27 user FlexInternalServlet: init
      20/09 17:04:27 info Deploying web application "Flex Admin Web Application" from:
      file:/D:/fds2/jrun4/servers/default/flex-admin/
      20/09 17:04:27 user JSPServlet: init
      20/09 17:04:28 info Deploying web application "Flex Data Services Samples" from:
      file:/D:/fds2/jrun4/servers/default/samples/
      20/09 17:04:28 user JSPServlet: init
      20/09 17:04:28 user FlexMxmlServlet: init
      20/09 17:04:28 INFO Loading configuration file D:\fds2\jrun4\servers\default\sam
      ples\WEB-INF\flex\flex-webtier-config.xml
      20/09 17:04:29 INFO Loading configuration file D:\fds2\jrun4\servers\default\sam
      ples\WEB-INF\flex\flex-config.xml
      20/09 17:04:29 user FlexMxmlServlet: Starting Adobe Flex Web Tier Compiler
      20/09 17:04:29 user FlexMxmlServlet: Adobe Flex Web Tier Compiler Build: 143451
      20/09 17:04:29 user MessageBrokerServlet: init
      20/09 17:04:30 user FlexSwfServlet: init
      20/09 17:04:30 user FlexInternalServlet: init
      [Flex] [ERROR] Exception when invoking service: data-service
      with message: Flex Message (flex.data.messages.DataMessage)
      operation = fill
      id = null
      clientId = A99D5E51-E3AB-867C-F536-CBCB4A1DE248
      correlationId =
      destination = cfcompany
      messageId = BA4828C1-C12C-71B0-5E46-CBCB4A4C3E50
      timestamp = 1158765300567
      timeToLive = 0
      body =
      hdr(DSEndpoint) = cf-dataservice-rtmp
      hdr(destClientIds) = {cfemployee=176763AA-EF0D-8ED3-F805-CBCB4A1D5A65}
      exception: flex.data.adapters.AdapterException: Error invoking fill-method 'fi
      ll' for destination cfcompany: Connection refused to host: 192.168.0.234; nested
      exception is:
      20/09 17:17:42 user FileServlet: init
      regards
      herbert
