2 Replies Latest reply on Sep 27, 2006 9:31 AM by amers
    Tree and Drag and Drop
    amers
      I have a small question on the Drag and Drop using the Tree component.
      private function dragEnterHandlerTree(event:DragEvent):void {
      var dropTarget:UIComponent = UIComponent(event.currentTarget);
      if (event.dragSource.hasFormat('treeItems'))
      // Signal that this data can be dropped onto the target
      DragManager.acceptDragDrop(dropTarget);
      trace("drag accepted.");
      DragManager.showFeedback(DragManager.COPY);
      trace(DragManager.getFeedback());
      var dragItems:Array = event.dragSource.dataForFormat("treeItems");
      now dragItems is an Array, it has the length of 1; but when I look at the information through a trace, it's empty.
      Any ideas on how to get the node's information? I've tried a couple different ways, one way had an issue and it read the tree node to be:
      <label="name" id="data" anotherID="id">
      any ideas?
      thanks!
        • 1. Re: Tree and Drag and Drop
          inlineblue Level 1
          The data is an XML object, so tracing it directly, as in trace(dragItems[0]), will output an empty string since the node doesn't have any content. You can trace dragItems[0].toXMLString() to get the full XML. And since it's an XML object, just use e4x operations to get at the data.
          • 2. Re: Tree and Drag and Drop
            amers Level 1
            thanks muchly!
            I was finally able to get the information and showing the XML helped quite a bit.
            trace("name: " + dragItems .@name);
            trace("ID: " + dragItems
            .@ID);
            After I got the information, I was able to successfully update the information using a web service. Now I'm having some issues on how to refresh the datagrid (since it's in it's own component).
            thanks again!
