3 Replies Latest reply on Oct 19, 2006 7:41 AM by Newsgroup_User
    Creating A Water Mark
    dz1
      Is there a way to create a transparent water mark with fireworks. I know how to adjust the transparency, but I do not get the effect like in professional photographs. Thanks in advance.
        • 1. Re: Creating A Water Mark
          llamaparsnip Level 1
          Do you have an example of the kind of watermark you want?
          • 2. Re: Creating A Water Mark
            Level 7
            On Thu, 19 Oct 2006 01:00:46 +0400, dz1 <webforumsuser@macromedia.com>
            Well, what are that "professional photographs" you are referring to? I've
            seen this effect applied as transparent color, as bump map, and in some
            other manners. Which one you call "professional"?
            Ilya Razmanov
            http://photoshop.msk.ru - Photoshop plug-in filters
            • 3. Re: Creating A Water Mark
              Level 7
              Not sure what you want to do. An easy way is to create the design you want
              in white then change the transparency until it looks good to you. If you
              are already doing this, it is probably fine enough.
              HTH,
              Tony
              "dz1" <webforumsuser@macromedia.com> wrote in message
              news:eh64lu$mm6$1@forums.macromedia.com...
