9 Replies Latest reply on Dec 21, 2006 9:26 AM by StevenErat
    "Using ColdFusion with Flex" samples dont work!
    Dr._Goomba
      Has anyone successfully gotten ANY of the FDS samples to work from the Flex and Coldfusion Dev Center?
      I am about to give up on using FDS, lack of documentation, no working examples, bugs, problems galore, grrrrrr!
      If you have gotten
      Using ColdFusion with Flex – Part 1: Creating and running a Contact Manager application
      or
      Using ColdFusion with Flex – Part 2: Creating and running a CRM application
      please post a step by step on how you got it to work. Thank you sooooooooooo much!!
        • 1. Re: "Using ColdFusion with Flex" samples dont work!
          LL@Work
          This is not the ONLY way but here is a simplified step-by-step approach to running the CRM Sample on Windows in 7 Steps:
          1. Download and Install Flex Data Services 2 Express to the built-in web server on port 8700 (default installation)
          http://www.adobe.com/go/tryflex
          2. Open a command window and go to c:\fds2\jrun4\bin
          3. Start the default server by typing jrun –start default
          4. Open a browser and request the sample apps page at http://localhost:8700/samples
          5. Click CRM Sample
          6. Click Run CRM
          7. Respond to the prompts to install Flash Player 9 if necessary
          (If mxml page is blank, close the browser and click on Run CRM again)
          You should see the Flex CRM sample application and data
          • 2. Re: "Using ColdFusion with Flex" samples dont work!
            LL@Work Level 1
            Sorry, I gave you instructions on the FDS CRM sample without the CF backend.
            Here are the steps to getting the Contact Manager application from http://www.adobe.com/devnet/flex/articles/coldfusionflex_part1.html up and running:
            2. Download and install ColdFusion MX 7.02 to the built in web server on port 8500
            http://www.adobe.com/go/trycoldfusion
            3. Download and install Flash Player 9
            http://www.adobe.com/go/getflashplayer
            4. Download and install Flex Builder 2 (for the ColdFusion Extensions)
            5. Download contact_sample.zip
            6. Unzip contactmgr.mxml, Hourglass.mxml, mini.mxml, wait.png, and Contact.as to C:\fds2\jrun4\servers\default\samples and be sure “Use folder names” is checked!
            7. Open C:\fds2\resources\config\services-config.xml in your favorite text editor
            8. Select and copy:
            <!-- ColdFusion specific RTMP channel -->
            <channel-definition id="cf-dataservice-rtmp" class="mx.messaging.channels.RTMPChannel">
            <endpoint uri="rtmp://{server.name}:2048" class="flex.messaging.endpoints.RTMPEndpoint"/>
            <properties>
            <idle-timeout-minutes>20</idle-timeout-minutes>
            <serialization>
            <!-- This must be turned off for any CF channel -->
            <instantiate-types>false</instantiate-types>
            </serialization>
            </properties>
            </channel-definition>
            <!-- ColdFusion specific HTTP channel -->
            <channel-definition id="cf-polling-amf" class="mx.messaging.channels.AMFChannel">
            <endpoint uri=" http://{server.name}:{server.port}/{context.root}/messagebroker/cfamfpolling" class="flex.messaging.endpoints.AMFEndpoint"/>
            <properties>
            <serialization>
            </serialization>
            <polling-enabled>true</polling-enabled>
            <polling-interval-seconds>8</polling-interval-seconds>
            </properties>
            9. Open C:\fds2\jrun4\servers\default\samples\WEB-INF\flex\services-config.xml in your favorite text editor
            10. Paste the copied text just under the last </channel-definition> tag and above the closing </channels> tag
            11. Save C:\fds2\jrun4\servers\default\samples\WEB-INF\flex\services-config.xml
            12. Open C:\fds2\jrun4\servers\default\samples\WEB-INF\flex\data-management-config.xml in your favorite text editor
            13. copy and paste the following to just under the last <adapter-definition id> tag and just above the </adapters> tag:
            <adapter-definition id="coldfusion-dao" class="coldfusion.flex.CFDataServicesAdapter"/>
            14. Open C:\fds2\resources\config\data-management-config.xml in your favorite text editor
            15. Select and copy:
            <!-- ColdFusion Sample - Contact sample application -->
            <destination id="cfcontact">
            through all of this code (roughly lines 288-395):
            Determines whether order is important for this filled collection. Allows for
            performance optimization when order is not important.
            Optional. Default value is true.
            <ordered>true</ordered>
            </fill-method>
            </server>
            </properties>
            </destination>
            16. Paste the copied text to C:\fds2\jrun4\servers\default\samples\WEB-INF\flex\data-management-config.xml just under the last </destination> and just above the </service> tag
            17. Unzip Contact.cfc, ContactDAO.cfc, ContactAssembler.cfc, test.cfm and contact.mdb to C:\CFusionMX7\wwwroot (Built-in web server root on port 8500) and be sure “Use folder names” is checked!
            18. Logon to the Coldfusion Administrator
            19. Create a datasource called FlexDataServices and point it to C:\CFusionMX7\wwwroot\contact_sample\samples\contact\db\contact.mdb (Be sure the datasource verifies ok)
            20. Create a mapping called samples mapped to C:\CFusionMX7\wwwroot\contact_sample\samples
            21. Test the Coldfusion side of the application by requesting http://{server_name}:8500/contact_sample/samples/contact/testContactAssembler.cfm
            You should see the following output:
            Output from Fill
            8 records
            Tom Jordahl
            Joe Doe
            Randy Crew
            Testing Man
            Jim Dandy
            Bill Sahlas
            William Chan
            Jack Sahlas
            22. Open C:\fds2\jrun4\servers\default\samples\contact_sample\dataservice\contact\contactmgr.mxml in your favorite text editor.
            23. Find this line of code: ds = new DataService("cfcontact");
            24. Change cfcontact to cfcontact-default
            25. Save and exit all edited files
            26. Start Flex by typing “jrun –start default” at c:\fds2\jrun4\bin
            27. Request the Contact Manager sample by requesting http://{server_name}:8700/samples/contact_sample/dataservice/contact/contactmgr.mxml
            28. You should see the Contact Manager application data
            • 3. Re: &quot;Using ColdFusion with Flex&quot; samples dont work!
              watsonValu Level 1
              Hi, I have a similar problem, as shown below: I think it is where I place the contact.as. I have moved this file to various positions but always get the same results. Can someone pse help cause 'I am dying here'.
              Watson
              Compilation Results
              Errors, warnings or exceptions were found while compiling /contact_sample/dataservice/contact/contactmgr.mxml. Visit the online Flex documentation or API reference for further information.
              4 Errors found.
              Error /contact_sample/dataservice/contact/contactmgr.mxml:31
              Definition samples.contact could not be found.
              30: import mx.rpc.events.*;
              31: import samples.contact.*;
              32:
              Error /contact_sample/dataservice/contact/contactmgr.mxml:37
              Type was not found or was not a compile-time constant: Contact.
              36: [Bindable]
              37: public var contact:Contact;
              38:
              Error /contact_sample/dataservice/contact/contactmgr.mxml:81
              Access of undefined property Contact.
              80: dg.selectedItem = event.item;
              81: contact = event.item as Contact;
              82: }
              Error /contact_sample/dataservice/contact/contactmgr.mxml:102
              Call to a possibly undefined method Contact.
              101: dg.selectedIndex = -1;
              102: contact = new Contact();
              103: }
              • 4. Re: &quot;Using ColdFusion with Flex&quot; samples dont work!
                LL@Work Level 1
                It looks like your contact.mxml can't find the contact.cfc
                Be sure you followed step #17 correctly.
                Was the test in step #21 successful?
                • 5. Re: &quot;Using ColdFusion with Flex&quot; samples dont work!
                  LL@Work Level 1
                  In response to a comment from this thread regarding steps #23 and #24, apparently they are not necessary:
                  An edit must have been made to the ":\fds2\jrun4\servers\default\samples\WEB-INF\flex\data-management-config.xml" file in the walk-through used for this step-by-step.
                  • 6. &quot;Using ColdFusion with Flex&quot; samples dont work!
                    Dr._Goomba Level 1
                    Im sorry, this is just exremely fustrating. I had it working once, now i cant get it to work again. When i had it working the first time, i modified the {server.name} with my IP address and it seemed to work. Doing it again however does not.
                    Now when i run this app at http://localhost:8700/samples/dataservice/cfcontact/contactmgr.mxml
                    I receive an immediate error stating: "error invoking fill-method 'fill' for destination cfcontact: Permission denied"
                    Question on #17 "be sure “Use folder names” is checked!" what is this referring too?
                    Here is what my configuration looks like:
                    <adapters>
                    <adapter-definition id="actionscript" class="flex.data.adapters.ASObjectAdapter" default="true"/>
                    <adapter-definition id="java-dao" class="flex.data.adapters.JavaAdapter"/>
                    </adapters>
                    <adapter ref="coldfusion-dao"/>
                    <channels>
                    <channel ref="cf-dataservice-rtmp"/>
                    <channel ref="cf-polling-amf"/>
                    </channels>
                    <properties>
                    <component>samples.contact.ContactAssembler</component>
                    <scope>request</scope>
                    <access>
                    <method-access-level>remote</method-access-level>
                    </access>
                    <property-case>
                    <force-cfc-lowercase>false</force-cfc-lowercase>
                    <force-query-lowercase>false</force-query-lowercase>
                    <force-struct-lowercase>false</force-struct-lowercase>
                    </property-case>
                    <metadata>
                    <identity property="contactId"/>
                    </metadata>
                    <network>
                    <!-- Add network elements here -->
                    </network>
                    <server>
                    <fill-method>
                    <use-fill-contains>false</use-fill-contains>
                    <auto-refresh>true</auto-refresh>
                    </fill-method>
                    </server>
                    </properties>
                    </destination>
                    <properties>
                    <serialization>
                    </serialization>
                    </properties>
                    <properties>
                    <serialization>
                    </serialization>
                    </properties>
                    <pattern>DataService.coldfusion</pattern>
                    CFCs are located at: C:\CFusionMX7\wwwroot\samples\contact
                    mappings: /samples C:\CFusionMX7\wwwroot\samples
                    http://localhost:8500/samples/contact/testContactAssembler.cfm is showing data returned.
                    Flex app is at: http://localhost:8700/samples/dataservice/cfcontact/contactmgr.mxml
                    My application files are at: C:\fds2\jrun4\servers\default\samples\dataservice\cfcontact
                    updated contactmgr.mxml with ds = new DataService("cfcontact");
                    Thanks for any ideas!!!
                    • 7. Re: &quot;Using ColdFusion with Flex&quot; samples dont work!
                      jpesolutions
                      I am getting this error
                      Compilation Results
                      1 Exception found.
                      Exception flex.messaging.config.ConfigurationException
                      Configuration error encountered on line 94, column 7: 'The element type "services-config" must be terminated by the matching end-tag "</services-config>".'
                      Any Ideas? I can't find the unterminated element.
                      • 8. Re: &quot;Using ColdFusion with Flex&quot; samples dont work!
                        hkk
                        hi,
                        i have teh same problem as "dr. goomba", but with the CRM sample.
                        i receive the error eror message:
                        "error invoking fill-method 'fill' for destination cfcompany: Permission denied"
                        coldfusion http://localhost
                        fds http://localhost:8700
                        i have changed all config files as described here:
                        www.adobe.com/devnet/flex/articles/coldfusionflex_part2_02.html
                        the console output does NOT display this infos:
                        [Flex] [CFDataServicesAdapter] Configuring CFC adapter for destination cfemployee
                        [Flex] [CFDataServicesAdapter] Configuring CFC adapter for destination cfcompany
                        thanks in advance
                        herbert
                        • 9. Re: &quot;Using ColdFusion with Flex&quot; samples dont work!
                          StevenErat Level 1
                          Before I discovered this forum thread, I fumbled through the application, but eventually figured out the various little problems with it. I blogged my annotations to the article here:
                          http://www.talkingtree.com/blog/index.cfm/2006/12/20/FDS-CFMX702-ContactManagerApp
                          In particular, I found that the most critical correction regards making the DataService creation match the same name used in the destination id for the Contact App destination.
                          The destination id already is "cfcontact" not "cfcontact-default", and by default the contactmgr.mxml initApp() method uses
                          ds = new DataService("cfcontact-default");
                          so that must be chnaged to
                          to match the desintation id
