0 Replies Latest reply on Oct 20, 2006 9:42 AM by maxonico
    Consuming Web Service Problem
    maxonico
      I'm having a problem from a long time ago, and I can't figure out how to solve it.
      I have a .NET object (PruebaEntidadAP) with the following properties:
      PruebaEntidadAP object:
      *Adress
      *Name
      *ColPrueba as ObjItem() (an object item array of type ObjItem)
      ObjItem object:
      *IDItem
      *ElementoItem
      I also have a web service with the following web methods:
      *' Returns an object PruebaEntidadAP
      FetchPrueba() as PruebaEntidadAP
      *' Updates the PruebaEntidadAP object
      UpdatePrueba(pUsu as PruebaEntidadAP)
      From Flex, I consume the web service calling the FetchPrueba method, it returns an object of type PruebaEntidadAP. I get and show the object in Flex and I also can acces to all it's properties, I even show the array ColPrueba into a Grid without problem.
      Later I send this object using the web method UpdatePrueba to modify it, there is where I get this error:
      RPC Fault, "uknown propery: IDItem" faultCode="EncodingError".
      If I do the same with an object that doesn't have a property representing an object's array, I mean a simple object without ColPrueba, it works. The problem is with the complex objects or those whom have collections in it.
      The same web service I consume from .NET and Visual Fox without problem, only Flex is giving me errors.
      You can see the web service at:
      http://www.managernet.com.ar/webservices/wssecurity.asmx
      the WSDL:
      http://www.managernet.com.ar/webservices/wssecurity.asmx?WSDL
      the application:
      http://www.managernet.com.ar/flex/managermain.html
      (Wait 1 sec., then click on Menu->Preuba Fetch and Update)
      the code:
      http://www.managernet.com.ar/flex/srcview/index.html
      Any idea on how to solve this problem?
      If you have any doubt, please ask me.
      Thanks.
